You have to run kubectl proxy from the same host as you are accessing your browser on.
I try that on same host where is installed MAAS/JUJU not on instance.
Ubuntu 18.04 Maas Server Edition
$:kubectl version
Client Version: version.Info{Major:"1", Minor:"14", GitVersion:"v1.14.2", GitCommit:"66049e3b21efe110454d67df4fa62b08ea79a19b", GitTreeState:"clean", BuildDate:"2019-05-16T16:23:09Z", GoVersion:"go1.12.5", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"14", GitVersion:"v1.14.2", GitCommit:"66049e3b21efe110454d67df4fa62b08ea79a19b", GitTreeState:"clean", BuildDate:"2019-05-16T16:14:56Z", GoVersion:"go1.12.5", Compiler:"gc", Platform:"linux/amd64"}
$:kubectl cluster-info
Kubernetes master is running at https://10.20.81.223:6443
Heapster is running at https://10.20.81.223:6443/api/v1/namespaces/kube-system/services/heapster/proxy
CoreDNS is running at https://10.20.81.223:6443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
Metrics-server is running at https://10.20.81.223:6443/api/v1/namespaces/kube-system/services/https:metrics-server:/proxy
Grafana is running at https://10.20.81.223:6443/api/v1/namespaces/kube-system/services/monitoring-grafana/proxy
InfluxDB is running at https://10.20.81.223:6443/api/v1/namespaces/kube-system/services/monitoring-influxdb:http/proxy
I try to open Grafana but dashboard ui nothing!
run kubectl proxy on the machine your browser is running on and access
http://localhost:8001/api/v1/namespaces/kube-system/services/https:kubernetes-dashboard:/proxy
in your browser
I’ve installed that on windows 10 and Mac, using this link, and in both case the result is the same:
Unable to connect to the server: dial tcp [::1]:8080: connectex: No connection could be made because the target machine actively refused it.
here is tasks on win
cd ~
PS C:\Users\rm> mkdir .kube
PS C:\Users\rm> cd .\Downloads
PS C:\Users\rm\Downloads> .\kubectl.exe config get-clusters
NAME
inside the .kube dir there is any file and not returns the name of the cluster, then I tried
PS C:\Users\rm\Downloads> .\kubectl.exe version -o yaml
clientVersion:
buildDate: "2019-03-25T15:53:57Z"
compiler: gc
gitCommit: 641856db18352033a0d96dbc99153fa3b27298e5
gitTreeState: clean
gitVersion: v1.14.0
goVersion: go1.12.1
major: "1"
minor: "14"
platform: windows/amd64
While on Maas
$:kubectl config get-clusters
NAME
juju-cluster
I think, my idea, being my lab built using this schema
Switch
|Maas+Juju |Juju Gui |Openstack
|10.20.81.1 |10.20.81.2 |10.20.81.21-24
Private Subnet-1 Public Subnet-2
10.1.0.0/24 10.20.81.0/24
|Juju| |K8s|
|Gui | | |
when I run the deploy of K8s, Juju creates on Openstack of the Grp policy with its own policy. Maybe that one blocks same requests from my Pc???
Looks like your kubeconfig isn’t setup and is preventing the rest from working. Scp the kubeconfig to ~/.kube/config similar to how it’s done in the kubernetes-core readme using juju scp. Get kubectl working correctly (put the config in the ~/.kube/ ) then the rest will work.
Yes Yes Yes…
in summary on Maas/Juju we’ve to run that:
$: mkdir -p ~/.kube
$: juju scp kubernetes-master/0:config ~/.kube/config
then on our Pc we need to Install kubectl locally and copy the config file from Maas to that in .kube dir.
clientVersion:
compiler: gc
gitTreeState: clean
gitVersion: v1.14.0
goVersion: go1.12.1
major: "1"
minor: "14"
serverVersion:
buildDate: "2019-05-16T16:14:56Z"
compiler: gc
gitCommit: 66049e3b21efe110454d67df4fa62b08ea79a19b
gitTreeState: clean
gitVersion: v1.14.2
goVersion: go1.12.5
major: "1"
minor: "14"
platform: linux/amd64
PS C:\Users\rm\Downloads> .\kubectl.exe proxy
Starting to serve on 127.0.0.1:8001
thanks
