Hello,
I’ve been working on a kubernetes charm for the site24x7 prometheus exporter, which lets you unify external end-to-end service monitoring with the rest of your metrics. Here’s how you can use it:
Credentials
You will need to have 2-factor auth enabled for your Zoho account in order to generate the correct credentials:
Set up a
Self Client
in the web interface (not any of the “Application” ones). This will provide you with theclient_id
andclient_secret
configuration settings. -
Go to your client’s
Generate Code
tab and create a temporary code with theScope
ofSite24x7.Reports.Read
and an expiration of10 minutes
. You can put whatever you like in the comment field, as this is just a temporary springboard to generate the real token. -
Use this temporary code and the id and secret from the other tab to fill out a file called
curl-secrets
(replacing the0xDEADBEEF
hex examples here with your credentials):
grant_type=authorization_code&
client_id=1000.DEADBEEFDEADBEEFDEADBEEFDEADBE&
client_secret=deadbeefdeadbeefdeadbeefdeadbeefdeadbeefde&
code=1000.deadbeefdeadbeefdeadbeefdeadbeef.deadbeefdeadbeefdeadbeefdeadbeef
Then run curl https://accounts.zoho.com/oauth/v2/token -X POST -d @curl-secrets
(adjusting for your regional zoho hostname). You will get a field back called refresh_token
which you’ll combine with your client id and secret in the final step:
Deploy
$ juju deploy cs:~prometheus-site24x7-exporter-charmers/site24x7-exporter --config client_id='1000.DEADBEEFDEADBEEFDEADBEEFDEADBE' --config client_secret='deadbeefdeadbeefdeadbeefdeadbeefdeadbeefde' --config refresh_token='1000.c0defacec0defacec0defacec0deface.c0defacec0defacec0defacec0deface'
Once the hooks have settled out, you should be able to browse curl http://${UNIT_IP:?}:9803/metrics
on the relevant unit IP. You can register it as an endpoint in your prometheus server, and be able to graph those metrics.
Bugs
There is a widely-reported issue whereby some Zoho accounts are able to use the refresh_token
to get a temporary auth token, but requests under that token fail with HTTP 401
errors. If you encounter this, please follow up on the issue with information about your setup.
Tests
This charm aims to keep 100% test coverage. To run the test suite, simply run make test
