Hi,
I’d like to propose our ceph-dashboard charm for listing. It’s been in use for a while as part of the OpenStack Charmers offering, and is being developed under the OpenStack umbrella.
I’ve filled out the form as per below, please let me know if there’s any questions.
Metadata links
- project repository:
https://opendev.org/openstack/charm-ceph-dashboard Mirrored at https://github.com/openstack/charm-ceph-dashboard
CI Links
- Code linting or-style checks:
We’re using flake8, tox.ini:
https://opendev.org/openstack/charm-ceph-dashboard/src/branch/master/tox.ini
- Release automation:
Build automation info is kept in https://github.com/openstack-charmers/charmed-openstack-info
- Unit test implementation:
https://opendev.org/openstack/charm-ceph-dashboard/src/branch/master/unit_tests
- Unit test results:
https://zuul.opendev.org/t/openstack/buildset/d74010eb63ea49e98e19ef4fd81cd43f
- Integration test implementation:
https://opendev.org/openstack/charm-ceph-dashboard/src/branch/master/tests https://github.com/openstack-charmers/zaza-openstack-tests
- Integration test results:
Documentation Links
- Usage:
Usage is documented here: Ceph Dashboard install | Ubuntu
- Contribution:
Developer info is kept as part of the OpenStack Charm Guide: https://docs.openstack.org/charm-guide/latest/
- Licensing:
https://opendev.org/openstack/charm-ceph-dashboard/src/branch/master/LICENSE
- Publisher:
We can be reached at openstack-discuss@lists.openstack.org
