Once you’ve created a backup file using juju create-backup
, you can restore the controller to an earlier snapshot using the stand-alone juju-restore
tool.
The restore tool is useful for rolling back to a previous backup, for example, if a juju upgrade-model
failed for some reason. It must be run on the primary controller. At a high level, it performs the following actions:
- Run various pre-checks, for example, ensuring the backup version matches the controller version
- Confirm with the user they definitely want to proceed
- Stop the controller agent
- Reinstate the model data in MongoDB using
mongorestore
(already installed on the controller) - Restart the controller agent
The tool works on high-availability (HA) controllers, as long as there’s SSH connectivity from the primary controller (where you run juju-restore
) to the secondary controller machines. We check for connectivity before beginning the restore, just in case.
Restoring a backup used to be done using the juju restore-backup
command. This command is now deprecated (and no longer works on controllers running Focal); use juju-restore
instead.
Installation
juju-restore
is written in Go and can be downloaded from the Releases tab of the GitHub project. To “install” juju-restore
, download the executable and copy it to the controller machine.
# Download the latest release binary (Linux, AMD64)
wget https://github.com/juju/juju-restore/releases/latest/download/juju-restore
chmod +x juju-restore
# Switch to the controller model
juju switch -m controller
# Copy juju-restore to the machine hosting the MongoDB primary
juju scp juju-restore 0:
Usage
juju-restore
should be run on the primary controller machine in the MongoDB replica set. This is typically machine 0 in the controller model. All replica set nodes need to be healthy and in PRIMARY
or SECONDARY
state.
juju-restore
requires a backup file created with juju create-backup
. If you saved a local copy, use juju scp
to copy this to the controller machine.
To perform the restore:
# SSH into the controller machine
juju ssh 0
# Start the restore! (it will ask for confirmation)
juju-restore /path/to/backup
Downgrading
By default, you can only restore from a backup created with exactly the same Juju version as the controller. If you run juju-restore
with the --allow-downgrade
option, you can also restore from a backup created with an earlier Juju version. This means that if you take a backup before upgrading the controller, and then hit a bug in the new Juju version, you can restore the backup to get back to the original version.
High availability (HA) operation
juju-restore
supports restoring backups to high availability controllers, and can automatically stop and restart Juju agents and Mongo daemons on the secondary controller machines. If --manual-agent-control
is specified or the user responds “no” when prompted, juju-restore
expects the user to do this manually.
Other options
Additional options include:
--yes
: answer “yes” to confirmation prompts (for non-interactive mode) -
--include-status-history
: restore the status history collection for machines and units (which can be large, and usually isn’t needed) -
--username
,--password
, and related options, to override the defaults for connecting to MongoDB
For the full list of options, type: juju-restore --help
