I deployed OpenStack using juju, via https://github.com/openstack-charmers/openstack-bundles/blob/master/stable/openstack-base/bundle.yaml
The Cloud has been working for couple days. It’s been deployed: 2021-03-09 21:23:17
When I looked at juju status
around 2021-03-11 15:46:38 I found out that juju status
is reporting error on vault/0
unit.
vault/0* error idle 24 10.5.0.14 8200/tcp hook failed: "update-status"
vault-mysql-router/0* active idle 10.5.0.14 Unit is ready
Please see attached logs from /var/log/juju/unit-vault-0.log
The event which caused outage was started around 2021-03-11 03:47:20
I finally managed to fix that by running juju resolved vault/0
, but I want to understand what caused this issue. I thought that might be caused by autoupdate to vault snap, but it doesn’t seem to be the case.
I’m out of ideas what could go wrong.
