I’ve been trying to port forward or create tunnel to access this dashboard since I installed kubeflow on my server. with the socks tunnel I get an error about the hostname not having an ip associated with it and I don’t know exactly how to deal with it
Hey, try this tutorial for setting up remote access to Kubeflow - Set up remote access | Charmed Kubeflow - hopefully it will help get you going
Rob
Hey, Is there a tutorial about how to use openebs as a default storage class in kubeflow ?
I am looking forward to your reply.
I tried to install kubeflow 1.6 on microk8s 1.22 over a few weeks but I do not succeed. I followed this quickguide and now all containers are up and running, but I cannot access the Web-UI with http://10.64.140.43.nip.io.
Further investigation showed that there is no gateway configured.
microk8s kubectl get gateway -A
so I tried this fix
cat <<EOF | kubectl create -f -
apiVersion: networking.istio.io/v1beta1
kind: Gateway
metadata:
labels:
app.istio-pilot.io/is-workload-entity: "true"
app.juju.is/created-by: istio-pilot
namespace: kubeflow
resourceVersion: "2203"
spec:
selector:
istio: ingressgateway
servers:
- hosts:
port:
number: 80
protocol: HTTP
EOF
but I got this error
error: error validating "STDIN": error validating data: [ValidationError(Gateway.metadata): unknown field "selector" in io.k8s.apimachinery.pkg.apis.meta.v1.ObjectMeta, ValidationError(Gateway.metadata): unknown field "servers" in io.k8s.apimachinery.pkg.apis.meta.v1.ObjectMeta]; if you choose to ignore these errors, turn validation off with --validate=false
My installation:
kubeflow microk8s-localhost microk8s/localhost 2.9.35 unsupported 23:22:56+02:00
admission-webhook res:oci-image@84a4d7d active 1 admission-webhook 1.6/stable 50 10.152.183.210 no
argo-controller res:oci-image@669ebd5 active 1 argo-controller 3.3/stable 99 no
dex-auth active 1 dex-auth 2.31/stable 129 10.152.183.230 no
istio-ingressgateway active 1 istio-gateway 1.11/stable 114 10.152.183.183 no
istio-pilot active 1 istio-pilot 1.11/stable 131 10.152.183.252 no
jupyter-controller res:oci-image@8f4ec33 active 1 jupyter-controller 1.6/stable 138 no
jupyter-ui res:oci-image@cde6632 active 1 jupyter-ui 1.6/stable 99 10.152.183.198 no
kfp-api res:oci-image@1b44753 active 1 kfp-api 2.0/stable 81 10.152.183.36 no
kfp-db mariadb/server:10.3 active 1 charmed-osm-mariadb-k8s latest/stable 35 10.152.183.47 no ready
kfp-persistence res:oci-image@31f08ad active 1 kfp-persistence 2.0/stable 76 no
kfp-profile-controller res:oci-image@d86ecff active 1 kfp-profile-controller 2.0/stable 61 10.152.183.142 no
kfp-schedwf res:oci-image@51ffc60 active 1 kfp-schedwf 2.0/stable 80 no
kfp-ui res:oci-image@55148fd active 1 kfp-ui 2.0/stable 80 10.152.183.236 no
kfp-viewer res:oci-image@7190aa3 active 1 kfp-viewer 2.0/stable 79 no
kfp-viz res:oci-image@67e8b09 active 1 kfp-viz 2.0/stable 74 10.152.183.212 no
kubeflow-dashboard res:oci-image@6fe6eec active 1 kubeflow-dashboard 1.6/stable 154 10.152.183.245 no
kubeflow-profiles res:profile-image@0a46ffc active 1 kubeflow-profiles 1.6/stable 82 10.152.183.168 no
kubeflow-roles active 1 kubeflow-roles 1.6/stable 31 10.152.183.193 no
kubeflow-volumes res:oci-image@cc5177a active 1 kubeflow-volumes 1.6/stable 64 10.152.183.141 no
metacontroller-operator active 1 metacontroller-operator 2.0/stable 48 10.152.183.178 no
minio res:oci-image@1755999 active 1 minio ckf-1.6/stable 99 10.152.183.2 no
oidc-gatekeeper res:oci-image@32de216 active 1 oidc-gatekeeper ckf-1.6/stable 76 10.152.183.79 no
seldon-controller-manager res:oci-image@eb811b6 active 1 seldon-core 1.14/stable 92 10.152.183.253 no
training-operator active 1 training-operator 1.5/stable 65 10.152.183.211 no
admission-webhook/0* active idle 10.1.85.150 4443/TCP
argo-controller/0* active idle 10.1.85.186
dex-auth/0* active idle 10.1.85.146
istio-ingressgateway/0* active idle 10.1.85.148
istio-pilot/0* active idle 10.1.85.149
jupyter-controller/0* active idle 10.1.85.175
jupyter-ui/0* active idle 10.1.85.178 5000/TCP
kfp-api/0* active idle 10.1.85.188 8888/TCP,8887/TCP
kfp-db/0* active idle 10.1.85.160 3306/TCP ready
kfp-persistence/0* active idle 10.1.85.187
kfp-profile-controller/0* active idle 10.1.85.184 80/TCP
kfp-schedwf/0* active idle 10.1.85.163
kfp-ui/0* active idle 10.1.85.189 3000/TCP
kfp-viewer/0* active idle 10.1.85.169
kfp-viz/0* active idle 10.1.85.182 8888/TCP
kubeflow-dashboard/0* active idle 10.1.85.172 8082/TCP
kubeflow-profiles/0* active idle 10.1.85.167 8080/TCP,8081/TCP
kubeflow-roles/0* active idle 10.1.85.152
kubeflow-volumes/0* active idle 10.1.85.171 5000/TCP
metacontroller-operator/0* active idle 10.1.85.153
minio/0* active idle 10.1.85.166 9000/TCP,9001/TCP
oidc-gatekeeper/0* active idle 10.1.85.185 8080/TCP
seldon-controller-manager/0* active idle 10.1.85.174 8080/TCP,4443/TCP
training-operator/0* active idle 10.1.85.155
It seems this fix is not working with microk8s Version 1.22.
Does anyone have an idea how to get kubeflow up and running?
Hello @ried Thank you for raising this. This command should force the charm to create the gateway by itself:
juju run --unit istio-pilot/0 -- "export JUJU_DISPATCH_PATH=hooks/config-changed; ./dispatch"
If it does not work the first time please try executing again. We will also update the quickstart guide with this new command.
I’m having the same issue with being unable to access the dashboard as others, copy/pasting the exact commands above on Ubuntu 20.04.
I have a gateway:
NAMESPACE NAME AGE
kubeflow kubeflow-gateway 57m
If I use this I can access the dashboard via localhost:9092, but as others have noted the subpages don’t work:
kubectl -n kubeflow port-forward svc/kubeflow-dashboard 9092:8082
I see 10.64.140.43 assigned to the external IP:
istio-ingressgateway-workload LoadBalancer 10.152.183.198 10.64.140.43 80:30680/TCP,443:31675/TCP 23h
Snap info for microk8s shows v1.22.15.
When I navigate to 10.64.140.43 in my browser, it redirects to 10.64.140.43.nip.io with some request params in the URL, but my browser shows: “Hmm. We’re having trouble finding that site.”
Running busybox in the namespace, I can wget http://10.64.140.43.nip.io and appear to get a login page, so that’s presumably what I’m looking for? But I don’t see it when accessing from a local browser outside busybox. Note this is not remote access, this is the same machine as my microk8s cluster.
Juju status shows everything green and idle.
Given this is a vanilla Ubuntu distro and local access, and I copy/pasted the commands exactly, I’d expect this to just work? But I did need to blast away the kubernetes cluster and rebuild once in the process due to the disk filling, and juju not cleaning up very well.
Help!
Hi @mmattb,
Sorry you’re having troubles. I’m not sure what is going wrong, but at least have a few questions.
In your post you said " When I navigate to 10.64.140.43 in my browser, it redirects to 10.64.140.43.nip.io" - did you mean the reverse? I’d expect 10.64.140.43.nip.io to redirect to the gateway at 10.64.140.43 (making everything look as if you’d gone to a public website with that name). I think based on your message you did it correctly but just had it backwards in the post, but fingers crossed this sorts everything out.
If that doesn’t help, I wonder if something gets in the way of how nip.io functions. I’m not an expert on DNS and such things, but I believe modem, router, and ISP configuration among other things can block what nip.io is doing. Can you test nip.io with something else in your network, to confirm it is the problem? I see posts like this git issue talking about solutions - trying this one or searching for other generic nip.io fixes might help.
Andrew
Looks like the tutorial for setting up remote access has been moved to this URL:
Hi,
Did you find a solution to this issue. I’ve followed the steps for a local install and cannot access the dashboard at http://10.64.140.43.nip.io/. It just times out.
Any guidance would be much appreciated!
Ben
Hey @pashleb,
Sorry you’re having trouble. Have you looked into the juju status or kubectl get pod -n kubeflow? That might have some clues on where to troubleshoot. Feel free to post them here, or even better open an issue on our github issue board so we can dig into it further.
I deployed KUbeflow 1.7 and UI was accesible with all functions working properly. After upgrading to KUbeflow 1.8 UI is not accessible anymore. All units are running with no error in juju debug-log. Could you please advise on what to check?
ubuntu@node06:~$ microk8s kubectl get gateway -A
NAMESPACE NAME AGE kubeflow istio-gateway 11h knative-serving knative-ingress-gateway 5h11m knative-serving knative-local-gateway 5h11m
Service details: istio-ingressgateway-workload LoadBalancer 10.152.183.20 172.27.80.162 80:30448/TCP,443:32371/TCP 11h
