Given the success of jhack show-relation
, I invested some time in bringing out v0.3 with a number of fancy updates:
- support for peer relations (!)
- support for showing relations in models other than the current one (
-m
) - optional suppression of empty databags (
-s
) - command promoted to toplevel jhack: it used to be nested under
utils
. Now you can simply dojhack show-relation
. - better cli help and shortcuts for lazy/busy typers.
- support for “show me the nth relation” instead of having to type out the whole
app-name:endpoint
thing: if you have 3 relations in your model, you can simply dojhack show-relation -n 1
and jhack will print out the 2nd relation from the top (of the same list appearing when you dojuju status --relations
, that is.
