As part of the Juju 2.8 release, juju-restore
is now available as a Developer Preview.
About
juju-restore
is a tool to restore a Juju backup file into a Juju controller. This may be required if a juju upgrade-model
failed for some reason. In a sense, it provides rollback functionality.
A restore can work backup that was taken from an earlier Juju version when the --allow-downgrade
option is passed. This means that if you take a backup before upgrading the controller, and then hit a bug in the new Juju version, you can restore the backup to get back to the original version.
This works on high-availability (HA) controllers, as long as there’s SSH connectivity from the primary controller (where you run juju-restore
) to the secondary controller machines. We check for connectivity before beginning the restore, just in case.
Installation
juju-restore
is written in Go and downloadable from the Releases tab of the GitHub project. To “install” juju-restore
, copy the executable onto the controller machine.
# Download the latest release
wget https://github.com/juju/juju-restore/releases/download/v0.9/juju-restore
# Switch to the controller model
juju switch -m controller
# Copy juju-restore to the machine hosting the MongoDB primary
juju scp juju-restore 0:/home/ubuntu
Usage
juju-restore
should be run on the primary controller machine in the MongoDB replica set. This is typically machine 0 in the controller model. All replica set nodes need to be healthy, in PRIMARY or SECONDARY state.
Requires backup:
juju-restore
requires a backup file to be in place. If you have saved a local copy, use juju scp
to copy this to the controller machine.
Usage syntax:
juju-restore [--allow-downgrade] <path-to-backup>
