N13 Constraints
A constraint is a user-defined minimum hardware specification for a machine that is spawned by Juju. There are a total of ten types of constraint, with the most common ones being ‘mem’, ‘cores’, ‘root-disk’, and ‘arch’. The definitive constraint resource is found on the Reference: Juju constraints page.
Several noteworthy constraint characteristics:
  • A constraint can be specified whenever a new machine is spawned with commands bootstrap, deploy, or add-machine.
  • Some constraints are only supported by certain clouds.
  • When used with deploy the constraint becomes the application’s default constraint.
  • Multiple constraints are logically ANDs (i.e. the machine must satisfy all constraints).
  • When used in conjunction with a placement directive (--to option), the placement directive takes precedence.
Clouds and constraints
The idealised use case is that of stipulating a constraint when deploying an application and the backing cloud providing a machine with those exact resources. In the majority of cases, however, default constraints may have been set (at various levels) and the cloud may be unable to supply those exact resources.
When the backing cloud is unable to precisely satisfy a constraint, the resulting system’s resources will exceed the constraint-defined minimum. However, if the cloud cannot satisfy a constraint at all then an error will be emitted and a machine will not be provisioned.
Constraints and LXD containers
Constraints can be applied to LXD containers either when they’re running directly upon a LXD cloud type or when hosted on a Juju machine (residing on any cloud type). However, with containers, constraints are interpreted as resource maximums as opposed to minimums.
In the absence of constraints, a container will, by default, have access to all of the underlying system’s resources.
LXD constraints also honour instance type names from either AWS, Azure, or GCE (e.g. AWS type ‘t2.micro’ maps to 1 CPU and 1 GiB of memory). When used in combination with specific CPU/MEM constraints the latter values will override corresponding instance type values.
Constraints and Kubernetes
Constraints in Kubernetes models control the resource requests and limits on the Pods spawned as a result of deploying an Application.
Memory and CPU constraints on side-car charms currently only represent requests used by Kubernetes for scheduling, and don’t set
limits and requests seperatley on each container. LP1919976 bug tracks this deficiency.
Constraint scopes, defaults, and precedence
Constraints can be applied to various levels or scopes. Defaults can be set on some of them, and in the case of overlapping configurations a precedence is adhered to. Changing a default does not affect existing machines.
On a per-controller basis, the following constraint scopes exist:
Among the scopes, default constraints can be set for each with the exception of the controller and single machines.
The all-units scope has its default set dynamically. It is the possible constraint used in the initial deployment of an application.
The following precedence is observed (in order of priority):
  1. Machine
  2. Application (and its units)
  3. Model
  4. All models
For instance, if a default constraint (‘mem’) applies to a single model and the same constraint has been stipulated when adding a machine (add-machine) within that model then the machine’s constraint value will be applied.
The dynamic default for units can be overridden by either setting the application’s default or by adding a machine with a constraint and then applying the new unit to that machine.
Setting constraints for a controller
Constraints are applied to the controller during its creation using the --bootstrap-constraints option:
juju bootstrap --bootstrap-constraints cores=2 google
Here, we want to ensure that the controller has at least two CPUs.
See Creating a controller for details and further examples.
Constraints applied with ‘–bootstrap-constraints’ will automatically apply to any future controllers provisioned for high availability. See Controller high availability.
Setting constraints for the initial ‘controller’ and ‘default’ models
Constraints can be applied to every machine (controller and non-controller) in the ‘controller’ and ‘default’ models. This is done, again, during the controller-creation process, but by using the --constraints option instead:
juju bootstrap --constraints mem=4G aws
See Creating a controller for more guidance.
Individual constraints from --bootstrap-constraints override any identical constraints from --constraints if these options are used in combination.
For the LXD cloud, the following invocation will place a limit of 2GiB of memory for each machine:
juju bootstrap --constraints mem=2G localhost
Setting and displaying constraints for a model
A model’s constraints are set, thereby affecting any subsequent machines in that model, with the set-model-constraints command:
juju set-model-constraints mem=4G
For the LXD cloud, all new machines in the current model will be limited to an instance type of ‘c5.large’ (2 CPU and 4 GiB):
juju set-model-constraints instance-type=c5.xlarge
A model’s constraints are displayed with the get-model-constraints command:
juju get-model-constraints
A model’s constraints can be reset by leaving the value part empty :
Setting, displaying, and updating constraints for an application
Constraints at the application level can be set at deploy time, via the deploy command. To deploy the ‘mariadb’ charm to a machine that has at least 4 GiB of memory:
juju deploy mariadb --constraints mem=4G
To deploy MySQL on a machine that has at least 6 GiB of memory and 2 CPUs:
juju deploy mysql --constraints "mem=6G cores=2"
Multiple constraints are space-separated and placed within quotation marks.
To deploy Apache and ensure its machine will have 4 GiB of memory (or more) as well as ignore a possible cores constraint (previously set at either the model or application level):
juju deploy apache2 --constraints "mem=4G cores="
For the LXD cloud, we deploy PostgreSQL using a combination of an instance type and a specific CPU constraint. Instance ‘c5.large’ maps to 2 CPU and 4 GiB but the specific memory constraint of 3.5 GiB yields a machine with 2 CPUs and 3.5 GiB of memory:
juju deploy postgresql --constraints "instance-type=c5.large mem=3.5G"
To deploy Zookeeper to a new LXD container (on a new machine) limited by 5 GiB of memory and 2 CPUs:
juju deploy zookeeper --constraints "mem=5G cores=2" --to lxd
To deploy two units of Redis across two AWS availability zones:
juju deploy redis -n 2 --constraints zones=us-east-1a,us-east-1d
An application’s current constraints are displayed with the get-constraints command:
juju get-constraints mariadb
An application’s constraints are updated, thereby affecting any additional units, with the set-constraints command:
juju set-constraints mariadb cores=2
An application’s default cannot be set until the application has been deployed.
Both the get-constraints and set-constraints commands work with application custom names. See Deploying applications for how to set a custom name.
Setting constraints when adding a machine
Constraints at the machine level can be set when adding a machine with the add-machine command. Doing so provides a way to override defaults at the all-units, application, model, and all-models levels.
Once such a machine has been provisioned it can be used for an initial deployment (deploy) or a scale out deployment (add-unit). See Deploying to specific machines for the command syntax to use.
A machine can be added that satisfies a constraint in this way:
juju add-machine --constraints arch=arm
To add a machine that is connected to a space, such as ‘storage’:
juju add-machine --constraints spaces=storage
If a space constraint is prefixed by ‘^’ then the machine will not be connected to that space. For example, given the following:
--constraints spaces=db-space,^storage,^dmz,internal
The resulting instance will be connected to both the ‘db-space’ and ‘internal’ spaces, and not connected to either the ‘storage’ or ‘dmz’ spaces.
See the network spaces page for details on spaces.
For a LXD cloud, to create a machine limited to two CPUs:
juju add-machine --constraints cores=2
To add eight Xenial machines such that they are evenly distributed among four availability zones:
juju add-machine -n 8 --series xenial --constraints zones=us-east-1a,us-east-1b,us-east-1c,us-east-1d
Aren’t we missing NULL?
I think it was originally worded badly. It doesn’t mean set the NULL value, it means set no value to unset the value.
Ah got it, I changed to this:
I am not too happy with this phrasing however, can you think about something better?
I made a slight change to the Kubernetes Constraints section.
@pedroleaoc I also updated the constraints reference Juju constraints
I feel like we need to make the constraints reference page more prominent here, not sure how.
Does this mean the constraints will be ignored if you use a placement directive?
@hpidcock I think you would be best suited to answer this question
Do you mean this reference should be more prominent?
I think the constraints relating to memory, cpu, instance-type etc are ignored and the machine’s actual values are the effective ones. Not sure how this affects lxd containers.
