N12 Controllers
Juju is an Open Source Charmed Operator Framework. It is composed of a
1. Charmed Operator Lifecycle Manager (OLM) that enables you to deploy, integrate, and manage Kubernetes native and VM native applications – across hybrid clouds.
2. Charmed Operator SDK that enables you to build Charmed Operators (often called “Charms”). Charms express operations and integration in a code package.
A controller is the management node of a Juju cloud environment. It runs the API server and the underlying database. Its overall purpose is to keep state of all the models, applications, and machines in that environment. Although it is a special node, it is a machine that gets created by Juju and, in that sense, is similar to any other Juju machine.
During controller creation two models are also created, the ‘controller’ model and the ‘default’ model. Additional models may be added by the user very easily.
The minimum resources required for a controller are 3.5 GiB of memory and 1 vCPU.
Controller Management Tasks
Common controller management tasks are summarised below. The most important one is Creating a controller.
Back up a controller
Juju allows one to create, restore and manage backup files containing the controller configuration/metadata. If the controller or its host machine fails, it is possible to recreate the controller from the backup. See Controller backups for assistance.
Configure a controller
There are many settings available for configuring a controller, such as whether the controller will record auditing information. Controller configuration must be passed at controller-creation time, although some exceptions exist (i.e. some changes can be made after creation). This topic is covered in more depth in Configuring controllers.
Controller high availability
Each controller can be made highly available to add resilience to the operations of the controller itself. This topic is covered on the Controller high availability page.
Create a controller
The creation of a controller is a hallmark step in the setting up of a Juju environment. See Creating a controller for examples.
Destroy a controller
When a controller is destroyed all associated models and applications are also removed. It is a very destructive process.
See the Removing things for a full explanation.
Disable commands
A controller administrator can restrict what sorts of changes a user can make across the controller’s models. This topic is treated on the Disabling commands page.
List controllers
Use the controllers command to list all controllers known to the client. The currently active controller is indicated in the list with an asterisk(’*’).
Log in to a controller
A user can log in to a controller in various ways. See page Controller logins for details.
Show controller details
Use the show-controller command to show details for a controller. Information includes UUID, API endpoints, certificates, and bootstrap configuration.
Use the Juju GUI
Each controller creates a web GUI as an alternative method of management. The GUI is capable of deploying, scaling, and monitoring applications, as well as more advanced operations. More details can be found on the Juju GUI page.
Possibly outdated
It’d be nice have a bit more about what a controller actually does: to start machines and create resources to bring the state of the cloud to match the model’s goal state (or something like that).
Not sure if you’re working against a style guide, but IMO more direct is better: “When a controller is created, two models…”
  • :+1:
Where is the “recipe” that the model follows? I understand the model is the “worker”, but I don’t know where the information comes from.
