Charmed MongoDB How-To | Manage client connections
How to manage client connections
Integrations (formerly “relations”) are connections between two applications with compatible endpoints. These connections simplify the creation and management of users, passwords, and other shared data.
Create a client connection to a bare replica set
To create a client connection to a replica set, simply integrate your client application with a Charmed MongoDB application running in replication mode.
The legacy mongodb interface is being deprecated soon. Integrations for client connections are now only supported via the mongodb_client interface.
If you do not have a client application that implements this interface, you can use the data-integrator charm.
To integrate mongodb with a client application, run:
juju integrate mongodb <application>
Remove client connection
To remove a client connection and the user associated with it:
juju remove-relation mongodb <application>
Create a client connection to a sharded cluster
To create a client connection to a sharded cluster, you must use the Charmed Mongos router.
mongos is a subordinate charm and must have a host charm. If you do not have a suitable host application, you may use the data-integrator charm.
To deploy mongos and data-integrator, run:
juju deploy mongos
juju deploy data-integrator [necessary options]
Wait for mongos’s status to be idle, then integrate it with data-integrator:
juju integrate mongos data-integrator
Next, integrate the mongos charm to a Charmed MongoDB application running as a config-server:
juju integrate config-server mongos
To remove a client connection to a sharded cluster:
juju remove-relation config-server mongos
Rotate the client password
To rotate client passwords, the integration should be removed and integrated again:
juju remove-relation <application> mongodb
juju integrate <application> mongodb
This process will generate a new user and password for the application. It works for both replica sets and sharded cluster client connections.
Internal operator user
The operator (i.e. admin) user is used internally by the Charmed MongoDB Operator. To rotate its password, use the set-password action.
To set a specific password for the operator user, run:
juju run mongodb/leader set-password password=<password>
To randomly generate a password for the operator user, run:
