Mattermost Documentation Plugins & Custom Images
Images are built via an OCI Recipe on Launchpad and pushed to mattermostcharmers/mattermost on dockerhub. Each image is tagged with the version number of Mattermost that it was built with (e.g. 5.29.0 ). The images published there are built using this Dockerfile.
Plugins
Plugins are also managed via the image build. The image builder does not enable any additional plugins by default, but examples of enabling prepackaged and downloaded plugins via the image_flavour build argument can be found on line 32 of the Dockerfile.
Webapp Customizations
To deploy changes to the Mattermost webapp itself (for example, we wrote a patch to add branded themes to our deployment) see line 39 onwards of the Dockerfile for details.
Local Image Builds
git clone https://git.launchpad.net/~mattermost-charmers/charm-k8s-mattermost/+git/image-build mattermost-image-build
docker build -t localhost:32000/mattermost ./mattermost-image-build
docker push localhost:32000/mattermost
Then, to use your new image, either replace the deploy step above with
juju deploy ./charm-k8s-mattermost/mattermost.charm --config mattermost_image_path=localhost:32000/mattermost:latest mattermost
or, if you’ve already deployed mattermost:
juju config mattermost mattermost_image_path=localhost:32000/mattermost:latest
