Machine authentication
Machines provisioned by Juju can be accessed via SSH. Juju supports managing SSH keys at the model level. Keys added to the model are placed on all machines (present and future) in the model.
Each Juju machine provides a user account named ‘ubuntu’ and it is to this account that public keys are added when using the Juju SSH commands add-ssh-key and import-ssh-key. Because this user is effectively the ‘root’ user (passwordless sudo privileges), the granting of SSH access must be done with due consideration.
It is possible to connect to a Juju machine in one of two ways:
Connecting via Juju involves a second degree of security, as explained below.
Regardless of the method used to connect, a public SSH key must be added to the model. In the case of direct access, it remains possible for a key to be added to an individual machine using standard methods (manually copying a key to the authorized_keys file or by way of a command such as ssh-import-id in the case of Ubuntu).
Juju ssh
When using Juju’s ssh (or scp) command, Juju’s internal user rights system imposes an extra degree of security by permitting access solely from a Juju user. This user must also have ‘admin’ model access. See Managing models in a multi-user context for help on assigning user permissions.
For example, to connect to a machine with an ID of ‘0’:
juju ssh 0
A machine hosting a particular unit can be connected to by using the unit ID:
juju ssh mysql/3
An interactive pseudo-terminal (pty) is enabled by default. For the OpenSSH client, this corresponds to the -t option (“force pseudo-terminal allocation”).
Remote commands can be run as expected. For example: juju ssh 1 lsb_release -c. For complex commands the recommended method is by way of the run command (see tutorial Basic client usage).
The scp command copies files securely to and from machines.
Options specific to scp must be preceded by double dashes: --.
Examples:
Copy 2 files from two MySQL units to the local backup/ directory, passing -v to scp as an extra argument:
juju scp -- -v mysql/0:/path/file1 mysql/1:/path/file2 backup/
Recursively copy the directory /var/log/mongodb/ on the first MongoDB server to the local directory remote-logs:
juju scp -- -r mongodb/0:/var/log/mongodb/ remote-logs/
Copy a local file to the second apache2 unit in the model “testing”. Note that the -m here is a Juju argument so the characters -- are not used:
juju scp -m testing foo.txt apache2/1:
Juju cannot transfer files between two remote units because it uses public key authentication exclusively and the native (OpenSSH) scp command disables agent forwarding by default. Either the destination or the source must be local (to the Juju client).
SSH keys and models
When a controller is either created or registered a passphraseless SSH keypair will be generated and placed under ~/.local/share/juju/ssh The public key juju_id_rsa.pub, as well as a possibly existing ~/.ssh/id_rsa.pub, will be placed within any newly-created model.
This means that a model creator will always be able to connect to any machine within that model (with juju ssh) without having to add keys since the creator is also granted ‘admin’ model access by default (see Adding a model for more information).
Recall that the creation of a controller effectively produces two models: ‘controller’ and ‘default’. This provides the initial controller administrator access to keys and models out of the box.
Providing access to non-initial controller admin Juju users
In order for a non-initial controller admin user to connect with juju ssh that user must:
  • be created (add-user)
  • have registered the controller (register)
  • be logged in (login)
  • have ‘admin’ access to the model
  • have their public SSH key reside within the model
  • be in possession of the corresponding private SSH key
As previously explained, ‘admin’ model access and installed model keys can be obtained by creating the model. Otherwise access needs to be granted (grant) by a controller admin and keys need to be added (add-ssh-key or import-ssh-key) by a controller admin or the model admin.
See Model access for how to grant rights to a model.
In terms of the private key, the easiest way to ensure it is used is to have it stored as ~/.ssh/id_rsa. Otherwise, you can do one of two things:
  1. Use ssh-agent
  2. Specify the key manually
The second option above, applied to the previous example, will look like this:
juju ssh 0 -i ~/.ssh/my-private-key
Use the ssh-keys command to list SSH keys currently permitting access to all machines, present and future, in a model.
Direct SSH access
When using a standard SSH client if one’s public key has been installed into a model, then, as expected, a connection to the ‘ubuntu’ user account can be made. All that is needed is the corresponding keypair and adequate network connectivity.
For example, to connect to a machine with an IP address of 10.149.29.143 with the OpenSSH client:
ssh ubuntu@10.149.29.143
the sentence: juju scp -r mongodb/0:/var/log/mongodb/ remote-logs/
has error, if you execute this, will get a error info:“option provided but not defined: -r”
the right instruction is : “juju scp – -r mongodb/0:/var/log/mongodb/ remote-logs/”
please attention to that instruction above, we have two hyphens,"–"
Thanks. Corrections made.
