Charmed OpenSearch | Load testing
How to perform load testing on Charmed OpenSearch
This guide will go over the steps for load testing your OpenSearch deployment with COS on AWS as the underlying cloud. These steps can be applied to Charmed OpenSearch on other types of private and public clouds. For more information, check Juju’s supported clouds documentation
  • juju v3.0+
    • This guide was written using v3.4
  • jq command-line tool
  • If not already available, a VPC set up on AWS (or the equivalent environment in your cloud of choice)
  • ACCESS_KEY and SECRET_KEY for AWS.
Installation and configuration
In this section, we will set up Juju and COS.
In the case of AWS, the first step is to select or setup a VPC for this test. We recommend to use one VPC with:
  • 1x public network with a jump host to allow the testing environment to be accessed
  • 1x private network (contains all the testing assets, such as OpenSearch nodes): it is not externally accessible and ensures deployments are isolated from internet access
Set up Juju
To use AWS with a VPC, set up the Juju controller as follows. Define the following environment variables:
  • JUJU_CONTROLLER_NAME: controller name of choice
  • VPC_ID: ID from AWS
  • VPC_PRIVATE_CIDR: network range where the deployment will happen
  • K8S_CLOUD_NAME: the k8s cluster name to be used on COS deployment later in this doc
Add credentials with the following command:
juju add-credentials aws
Example output:
This operation can be applied to both a copy on this client and to the one on a controller.
No current controller was detected but there are other controllers registered: use -c or --controller to specify a controller if needed.
Do you ONLY want to add a credential to this client? (Y/n): Y
Enter credential name: aws_creds
Regions
  us-east-1
  us-east-2
  us-west-1
  us-west-2
  ca-central-1
  eu-west-1
  eu-west-2
  eu-west-3
Select region [any region, credential is not region specific]: us-east-1
Using auth-type "access-key".
Enter access-key:
Enter secret-key:
Credential "aws_creds" added locally for cloud "aws".
Then, bootstrap the controller with the previously defined environment variables:
juju bootstrap aws $JUJU_CONTROLLER_NAME \
    --credential aws_creds \
    --model-default container-networking-method=local \
    --config vpc-id=$VPC_ID \
    --config vpc-id-force=true \
    --constraints 'instance-type=t2.medium  root-disk=100G' \
    --to subnet=$VPC_PRIVATE_CIDR
Set up COS
Deploy Kubernetes
Deploy a K8s cluster.
This document uses Microk8s. Installation instructions can be found in COS documentation.
Optionally, configure kubectl with microk8s’s access:
# If kubectl is not yet available
sudo snap install kubectl --classic \
    --channel=<same as microk8s>
sudo microk8s config > ~/.kube/config
Deploy COS
The remainder of this section will consider that you have successfully deployed a K8s cluster and your local kubectl is configured to connect with that cluster. The cluster must be configured with a LoadBalancer service.
Download the COS overlay bundle.
Add the K8s cluster to Juju as new cloud:
juju add-k8s $K8S_CLOUD_NAME \
    --client --controller $JUJU_CONTROLLER_NAME
juju add-model cos $K8S_CLOUD_NAME
# Get the overlay that sets cos offerings up
wget https://raw.githubusercontent.com/canonical/cos-lite-bundle/main/overlays/offers-overlay.yaml
juju deploy cos-lite --trust \
    --overlay ./offers-overlay.yaml
Access Prometheus and Grafana
Once the deployment is complete, check the IP that Traefik’s Load Balancer service got allocated:
kubectl get svc -A | grep traefik | grep LoadBalancer | awk '{print $5}'
The password for grafana can be retrieved with the following command:
juju run -m cos grafana/leader get-admin-password
Access the Prometheus and Grafana respectively on:
  • http://<TRAEFIK_IP>/cos-prometheus-0/graph
  • http://<TRAEFIK_IP>/cos-grafana
cos-grafana has the username “admin”.
Deploy OpenSearch
Add a model to your controller and configure it:
juju add-model opensearch aws \
    --config container-networking-method=local \
juju model-config cloudinit-userdata="postruncmd:
        - [ 'sysctl', '-w', 'vm.max_map_count=262144' ]
        - [ 'sysctl', '-w', 'fs.file-max=1048576' ]
        - [ 'sysctl', '-w', 'vm.swappiness=0' ]
        - [ 'sysctl', '-w', 'net.ipv4.tcp_retries2=5' ]"
juju add-space -m opensearch internal-space \
    $VPC_PRIVATE_CIDR
Deploy the self-signed-certificates charm, create a storage pool, and integrate with opensearch:
juju deploy self-signed-certificates \
    --constraints="arch=amd64 instance-type=t2.medium root-disk=100G spaces=internal-space" \
    --bind "internal-space"
juju create-storage-pool \
    opensearch ebs volume-type=gp3
juju deploy opensearch \
    --channel=2/edge -n3 \
    --constraints="arch=amd64 instance-type=r5.xlarge root-disk=200G spaces=internal-space" \
    --bind "internal-space" \
    --storage opensearch-data=opensearch,512G
juju integrate self-signed-certificates opensearch
Integrate with COS
Import the Juju relation offers from COS into OpenSearch’s model:
juju consume admin/cos.alertmanager-karma-dashboard
juju consume admin/cos.grafana-dashboards
juju consume admin/cos.loki-logging
juju consume admin/cos.prometheus-receive-remote-write
And relate it with OpenSearch:
juju deploy grafana-agent
juju integrate opensearch grafana-agent
juju integrate grafana-agent grafana-dashboards
juju integrate grafana-agent loki-logging
juju integrate grafana-agent prometheus-receive-remote-write
Run OpenSearch benchmark
(Optional) Add a machine to manage the workload
juju deploy ubuntu \
--constraints="arch=amd64 instance-type=r5.xlarge root-disk=opensearch,512G" --bind internal-space
Discover the cluster details
Discover the IP and password to be used for this test. Set them as environment variable OPENSEARCH_PWD.
juju run opensearch/leader get-password
Pick the password and set to the environment variable OPENSEARCH_PWD.
Start the benchmark
Update or install dependencies:
sudo apt update
sudo apt upgrade -y # if needed
sudo apt install -y python3-pip
pip install opensearch-benchmark
The opensearch-benchmark command can be executed with the different workloads now. Set the opensearch hosts and start test:
export OPENSEARCH_HOSTS="$(juju status --format=json | jq -r '.applications.opensearch.units[] | ."public-address"' | sed 's/.*/https:\/\/&:9200/' | paste -s -d, -)"
opensearch-benchmark execute-test \
    --target-hosts $OPENSEARCH_HOSTS \
    --pipeline benchmark-only \
    --workload nyc_taxis \
    --client-options basic_auth_user:admin,basic_auth_password:$OPENSEARCH_PWD,verify_certs:false
