Usage:
juju update-public-clouds [options]
Summary:
Updates public cloud information available to Juju.
Global Options:
--debug (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help (= false)
--logging-config (= "")
specify log levels for modules
--quiet (= false)
show no informational output
--show-log (= false)
if set, write the log file to stderr
--verbose (= false)
show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client (= false)
Client operation
--local (= false)
DEPRECATED (use --client
): Local operation only; controller not affected
Details:
If any new information for public clouds (such as regions and connection endpoints) are available this command will update Juju accordingly. It is suggested to run this command periodically.
Use --controller
option to update public cloud(s) on a controller. The command
will only update the clouds that a controller knows about.
Use --client
to update a definition of public cloud(s) on this client.
Examples:
juju update-public-clouds --client
juju update-public-clouds --controller mycontroller
See also:
clouds
