Usage:
juju show-credential [options] [<cloud name> <credential name>]
Summary:
Shows credential information stored either on this client or on a controller.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client (= false)
Client operation
--format (= yaml)
Specify output format (yaml)
--local (= false)
DEPRECATED (use --client): Local operation only; controller not affected
-o, --output (= "")
Specify an output file
--show-secrets (= false)
Display credential secret attributes
Details:
This command displays information about cloud credential(s) stored either on this client or on a controller for this user.
To see the contents of a specific credential, supply its cloud and name. To see all credentials stored for you, supply no arguments.
To see secrets, content attributes marked as hidden, use --show-secrets option.
To see credentials from this client, use “–client” option.
To see credentials from a controller, use “–controller” option.
Examples:
juju show-credential google my-admin-credential
juju show-credentials
juju show-credentials --controller mycontroller --client
juju show-credentials --client
juju show-credentials --show-secrets
See also:
credentials
add-credential
update-credential
remove-credential
autoload-credentials
Aliases:
show-credentials
