`juju show-cloud`
Usage:
juju show-cloud [options] <cloud name>
Summary:
Shows detailed information for a cloud.
Global Options:
--debug  (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help  (= false)
--logging-config (= "")
specify log levels for modules
--quiet  (= false)
show no informational output
--show-log  (= false)
if set, write the log file to stderr
--verbose  (= false)
show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client  (= false)
Client operation
--format  (= yaml)
Specify output format (yaml)
--include-config  (= false)
Print available config option details specific to the specified cloud
--local  (= false)
DEPRECATED (use --client): Local operation only; controller not affected
-o, --output (= "")
Specify an output file
Details:
Provided information includes ‘defined’ (public, built-in), ‘type’, ‘auth-type’, ‘regions’, ‘endpoints’, and cloud specific configuration options.
If --include-config is used, additional configuration (key, type, and description) specific to the cloud are displayed if available.
Use --controller option to show a cloud from a controller.
Use --client option to show a cloud known on this client.
Examples:
juju show-cloud google
juju show-cloud azure-china --output ~/azure_cloud_details.txt
juju show-cloud myopenstack --controller mycontroller
juju show-cloud myopenstack --client
juju show-cloud myopenstack --client --controller mycontroller
See also:
clouds
add-cloud
update-cloud
