Usage:
juju set-model-constraints [options] <constraint>=<value> ...
Summary:
Sets machine constraints on a model.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
Details:
Sets constraints on the model that can be viewed with
juju get-model-constraints
. By default, the model is the current model.
Model constraints are combined with constraints set for an application with
juju set-constraints
for commands (such as ‘deploy’) that provision
machines/containers for applications. Where model and application constraints overlap, the
application constraints take precedence.
Constraints for a specific application can be viewed with juju get-constraints
Examples:
juju set-model-constraints cores=8 mem=16G
juju set-model-constraints -m mymodel root-disk=64G
See also:
models
get-constraints
set-constraints
