The Charmed Operator Software Development Kit (SDK) is a toolkit for packaging applications—in a special format called Charmed Operators (‘charms’)—for the cloud. It is a component of the Charmed Operator Framework Juju and it consists of the command line tool Charmcraft (charmcraft
) and the Python charmed operator framework Ops (ops
The SDK provides commands and templates to package both Kubernetes and non-Kubernetes applications in one standard format with the extension “.charm”. These can be subsequently deployed using Juju’s Charmed Operator Lifecycle Manager (OLM).
As such, the SDK makes it quick and easy to make applications of any type ready for the cloud.
For DevOps, Juju’s SDK simplifies workflow; for CIOs, it helps reimagine solutions, as it lowers the barrier for including new applications.
For a collection of existing charms, see Charmhub. To deploy and manage an existing or new charm, see the Charmed Operator Lifecycle Manager (OLM).
In this documentation
Tutorials Get started - a hands-on introduction to the Juju SDK for new users |
Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
The Juju SDK is an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Learn about the Roadmap
- Read our Code of Conduct
- Join the Mattermost community chat
- Join the Discourse community forum
- Report a bug on Github
- Contribute on Github
- Visit the Juju careers page
Navigation
Navigation
Level | Path | Navlink |
0 | Juju SDK documentation | |
0 | tutorials | Tutorials |
build-and-deploy-minimal-machine-charm | Build and deploy a minimal machine charm | |
build-and-deploy-minimal-kubernetes-charm | Build and deploy a minimal Kubernetes charm | |
Build a Charmed Operator for Kubernetes (video) | ||
build-a-minimal-operator | Build your first Kubernetes operator | |
0 | how-to | How-to guides |
setup | Set-up | |
create-an-ubuntu-virtual-machine-with-multipass | Create an Ubuntu virtual machine with Multipass | |
dev-setup | Development setup | |
install-charmcraft | Install Charmcraft | |
charmcraft-config | Configure Charmcraft | |
remote-env-auth | Authenticate Charmcraft in remote environments | |
hello-world | Hello, world | |
manage-charms | Manage charms | |
initialise-your-charm | Initialise your charm | |
change-step-behavior-in-a-charm | Change step behavior when creating a charm | |
build-your-charm | Pack your charm | |
pack-your-reactive-based-charm-with-charmcraft | Pack your reactive-based charm with Charmcraft | |
workloads | Run workloads with your charm | |
pack-your-hooks-based-charm-with-charmcraft | Pack your hooks-based charm with Charmcraft | |
logging | Configure logging in your charm | |
config | Handle charm configuration | |
testing | Test your charm | |
write-an-integration-test-for-a-charm | Write an integration test for a charm | |
deploy-your-charm | Deploy your charm | |
charm-documentation | Document your charm: The README file | |
publishing | Publish your charm to Charmhub | |
add-docs-to-your-charmhub-page | Add docs to your charm page on Charmhub | |
create-an-icon-for-your-charm | Create an icon for your charm | |
interact-with-pebble | Interact with Pebble | |
actions | Handle actions | |
resources | Manage charm resources | |
define-a-resource-for-your-charm | Define a resource for your charm | |
associate-a-resource-to-your-charm | Associate a resource to your charm | |
publishing-resources | Publish a resource to Charmhub | |
attach-a-resource-to-a-charm-at-release-time | Attach a resource to a charm at release time | |
access-a-resource-from-your-charm | Access a resource from your charm | |
manage-libraries | Manage charm libraries | |
find-and-use-a-charm-library | Find and use a charm library | |
create-and-publish-a-charm-library | Create and publish a charm library | |
document-your-charm-library | Document your charm library | |
manage-bundles | Manage charm bundles | |
create-a-charm-bundle | Create a charm bundle | |
configure-a-charm-bundle | Configure a charm bundle | |
set-charm-channels-within-a-bundle | Set charm channels within a bundle | |
set-charm-constraints-within-a-bundle | Set charm constraints within a bundle | |
set-charm-options-within-a-bundle | Set charm options within a bundle | |
integrate-a-local-charm-into-a-bundle | Integrate a local charm into a bundle | |
add-an-overlay-bundle | Add an overlay bundle | |
append-an-overlay-bundle-to-a-base-bundle | Append an overlay bundle to a base | |
resolve-a-relative-path-inside-a-bundle | Resolve a relative path inside a bundle | |
remove-an-application-from-a-bundle | Remove an application from a bundle | |
replace-machines-in-a-bundle | Replace machines in a bundle | |
modify-relations-inside-a-bundle | Modify relations inside a bundle | |
add-machine-specifications-to-a-bundle | Add machine specifications to a bundle | |
bind-endpoints-within-a-bundle | Bind endpoints within a bundle | |
specify-application-expose-parameters-within-a-bundle | Specify application expose parameters within a bundle | |
use-charm-resources-in-a-bundle | Use charm resources in a bundle | |
recycle-machines-in-a-bundle | Recycle machines in a bundle | |
add-a-placement-directive-to-a-bundle | Add placement directives to a bundle | |
add-storage-directives-to-a-bundle | Add storage directives to a bundle | |
set-up-subordinate-charms-inside-a-bundle | Set up subordinate charms inside a bundle | |
compare-a-bundle-to-a-model | Compare a bundle to a model | |
pack-a-charm-bundle | Pack a charm bundle | |
deploy-a-charm-bundle | Deploy a charm bundle | |
publish-a-charm-bundle-to-charmhub | Publish a charm bundle to Charmhub | |
0 | reference | Reference |
charmcraft-cli-commands | Charmcraft CLI commands | |
charmcraft-analyze | analyze | |
charmcraft-clean | clean | |
charmcraft-close | close | |
charmcraft-create-lib | create-lib | |
charmcraft-fetch-lib | fetch-lib | |
charmcraft-init | init | |
charmcraft-list-lib | list-lib | |
charmcraft-login | login | |
charmcraft-logout | logout | |
charmcraft-names | names | |
charmcraft-pack | pack | |
charmcraft-publish-lib | publish-lib | |
charmcraft-register | register | |
charmcraft-register-bundle | register-bundle | |
charmcraft-release | release | |
charmcraft-resource-revisions | resource-revisions | |
charmcraft-resources | resources | |
charmcraft-revisions | revisions | |
charmcraft-status | status | |
charmcraft-upload-resource | upload-resource | |
charmcraft-upload | upload | |
charmcraft-version | version | |
charmcraft-whoami | whoami | |
ops-classes | Ops classes | |
Tools, entities, processes | ||
charmcraft | charmcraft |
charmcraft-deprecations | Charmcraft deprecation notices | |
charm-bundles | Bundle | |
kubernetes-vs-non-kubernetes-bundles | Kubernetes vs. non-Kubernetes bundles | |
charmed-operators | Charmed operator (‘charm’) | |
charm-types-by-deployment-type | Charms, by deployment type | |
charm-types-by-development-type | Charms, by development type | |
charm-anatomy | Charm anatomy | |
event–hook | Event / hook | |
events | Core lifecycle events | |
charm-libraries | Library | |
the-location-of-a-charm-library-inside-a-charm | The location of a charm library inside a charm | |
library-index | Popular charm library index | |
ops | ops |
pebble | Pebble |
relations | Relation | |
about-resources | Resource | |
storage | Storage | |
Other reference | ||
a-charms-life | A charm’s life | |
charmcraft-analyze | Analyzers and linters | |
metadata-reference | Charm metadata reference | |
debugging | Debugging | |
constructs | Framework constructs | |
hook-tools | Hook tools | |
leadership | Leadership | |
integration-testing-cookbook | Integration testing cookbook | |
stored-state-uses-limitations | StoredState: Uses, Limitations | |
api-reference | API reference | |
INTEGRATE WITH EXISTING MATERIAL | ||
libraries | Libraries | |
yaml-anchors-and-aliases | YAML anchors and aliases | |
0 | explanation | Explanation |
deferring-events-details-and-dilemmas | Deferring events: Details and dilemmas | |
history | Charming history | |
assumes | Assumes | |
styleguide | Charm development best practices | |
naming | Charm naming guidelines | |
roadmap | Roadmap |
Redirects
Mapping table
Location | Path |
/docs/sdk/charm-types | /docs/sdk/charm-types-by-destination-type |
/docs/sdk/setting-up-charmcraft | /docs/sdk/install-charmcraft |
/docs/sdk/bundles | /docs/sdk/publish-a-charm-bundle-to-charmhub |
/docs/sdk/bundle-reference | /docs/sdk/manage-bundles |
/docs/sdk/charmcraft-libraries | /docs/sdk/manage-libraries |
