`juju remove-credential`
Usage:
juju remove-credential [options] <cloud name> <credential name>
Summary:
Removes Juju credentials for a cloud.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client  (= false)
Client operation
--force  (= false)
Force remove controller side credential, ignore validation errors
--local  (= false)
DEPRECATED (use --client): Local operation only; controller not affected
Details:
The credential to be removed is specified by a “credential name”. Credential names, and optionally the corresponding authentication material, can be listed with juju credentials.
Use --controller option to remove credentials from a controller.
When removing cloud credential from a controller, Juju performs additional checks to ensure that there are no models using this credential.
Occasionally, these check may not be desired by the user and can be by-passed using --force.
If force remove was performed and some models were still using the credential, these models will be left with un-reachable machines. Consequently, it is not recommended as a default remove action.
Models with un-reachable machines are most commonly fixed by using another cloud credential, see ’ + “‘juju set-credential’” + ’ for more information.
Use --client option to remove credentials from the current client.
Examples:
juju remove-credential google credential_name
juju remove-credential google credential_name --client
juju remove-credential google credential_name -c mycontroller
juju remove-credential google credential_name -c mycontroller --force
See also:
add-credential
autoload-credentials
credentials
default-credential
set-credential
update-credential
