Usage:
juju register [options] <registration string>|<controller host name>
Summary:
Registers a controller.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
Details:
The register
command adds details of a controller to the local system.
This is done either by completing the user registration process that
began with the ‘juju add-user’ command, or by providing the DNS host
name of a public controller.
To complete the user registration process, you should have been provided with a base64-encoded blob of data (the output of ‘juju add-user’) which can be copied and pasted as the argument to ‘register’. You will be prompted for a password, which, once set, causes the registration string to be voided. In order to start using Juju the user can now either add a model or wait for a model to be shared with them. Some machine providers will require the user to be in possession of certain credentials in order to add a model.
When adding a controller at a public address, authentication via some external third party (for example Ubuntu SSO) will be required, usually by using a web browser.
Examples:
juju register MFATA3JvZDAnExMxMDQuMTU0LjQyLjQ0OjE3MDcwExAxMC4xMjguMC4yOjE3MDcwBCBEFCaXerhNImkKKabuX5ULWf2Bp4AzPNJEbXVWgraLrAA=
juju register public-controller.example.com
See also:
add-user
change-user-password
unregister
