Usage:
juju payloads [options] [pattern ...]
Summary:
Display status information about known payloads.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
--format (= tabular)
Specify output format (json|tabular|yaml)
-m, --model (= "")
Model to operate in. Accepts [:]|
-o, --output (= "")
Specify an output file
Details:
This command will report on the runtime state of defined payloads.
When one or more pattern is given, Juju will limit the results to only those payloads which match any of the provided patterns. Each pattern will be checked against the following info in Juju:
- unit name
- machine id
- payload type
- payload class
- payload id
- payload tag
- payload status
Aliases:
list-payloads
