`juju models`
Usage:
juju models [options]
Summary:
Lists models a user can access on a controller.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--all  (= false)
Lists all models, regardless of user accessibility (administrative users only)
-c, --controller (= "")
Controller to operate in
--exact-time  (= false)
Use full timestamps
--format  (= tabular)
Specify output format (json|tabular|yaml)
-o, --output (= "")
Specify an output file
--user (= "")
The user to list models for (administrative users only)
--uuid  (= false)
Display UUID for models
Details:
The models listed here are either models you have created yourself, or models which have been shared with you. Default values for user and controller are, respectively, the current user and the current controller. The active model is denoted by an asterisk.
Examples:
juju models
juju models --user bob
See also:
add-model
share-model
unshare-model
Aliases:
list-models
