`juju model-defaults`
Usage:
juju model-defaults [options] [[<cloud>/]<region> ]<model-key>[<=value>] ...]
Summary:
Displays or sets default configuration settings for new models.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--format  (= tabular)
Specify output format (json|tabular|yaml)
--ignore-read-only-fields  (= false)
Ignore read only fields that might cause errors to be emitted while processing yaml documents
-o, --output (= "")
Specify an output file
--reset  (= )
Reset the provided comma delimited keys
Details:
By default, all default configuration (keys and values) are displayed if a key is not specified. Supplying key=value will set the supplied key to the supplied value. This can be repeated for multiple keys. You can also specify a yaml file containing key values.
Model default configuration settings are specific to the cloud on which the model is deployed.
If the controller host more then one cloud, the cloud (and optionally region) must be specified.
Model defaults yaml configuration can be piped from stdin from the output in yaml format of the command stdout.
Some model-defaults configuration are read-only, to prevent the command exiting on read-only fields, setting “ignore-read-only-fields” will cause it to skip over the fields when they’re encountered.
Examples:
Display all model config default values
juju model-defaults
Display the value of http-proxy model config default
juju model-defaults http-proxy
Display the value of http-proxy model config default for the aws cloud
juju model-defaults aws http-proxy
Display the value of http-proxy model config default for the aws cloud and us-east-1 region
juju model-defaults aws/us-east-1 http-proxy
Display the value of http-proxy model config default for the us-east-1 region
juju model-defaults us-east-1 http-proxy
Set the value of ftp-proxy model config default to 10.0.0.1:8000
juju model-defaults ftp-proxy=10.0.0.1:8000
Set model default values for the us-east-1 region as defined in path/to/file.yaml and ftp-proxy on the command line
juju model-defaults us-east-1 ftp-proxy=10.0.0.1:8000 path/to/file.yaml
Set model default values for the aws cloud as defined in path/to/file.yaml
juju model-defaults aws path/to/file.yaml
Reset the value of default-series and test-mode to default
juju model-defaults --reset default-series,test-mode
Reset the value of http-proxy for the us-east-1 region to default
juju model-defaults us-east-1 --reset http-proxy
See also:
models
model-config
Aliases:
model-default
