Plugin `juju-metadata`
If you’ve installed juju via snap, this plugin is probably already on your $PATH, so you can go ahead and use it as you would any other juju command.
Usage:
juju metadata [flags] <command> ...
Summary:
tools for generating and validating image and tools metadata
Flags:
--debug  (= false)
--description  (= false)
Show short description of plugin, if any
-h, --help  (= false)
--log-file (= "")
Path to write log to
--logging-config (= "")
-q, --quiet  (= false)
Show no informational output
--show-log  (= false)
-v, --verbose  (= false)
Show more verbose output
Details:
Juju metadata is used to find the correct image and agent binaries when bootstrapping a Juju model.
commands:
add-image       - adds image metadata to model
delete-image    - deletes image metadata from environment
generate-agents - generate simplestreams agent metadata
generate-image  - generate simplestreams image metadata
generate-tools  - Alias for 'generate-agents'.
help            - Show help on a command or other topic.
list-images     - lists cloud image metadata used when choosing an image to start
sign            - sign simplestreams metadata
validate-agents - check that compressed tar archives (.tgz) for the Juju agent binaries are available
validate-images - validate image metadata and ensure image(s) exist for a model
validate-tools  - Alias for 'validate-agents'.
