`juju list-regions`
Alias for juju regions.
@owenrm
I am not too sure what you are after but the help output for ‘regions’ is a lot more comprehensive:
$ juju help regions
Usage: juju regions [options] <cloud>
Summary:
Lists regions for a given cloud.
Global Options:
--debug  (= false)
    equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help  (= false)
--logging-config (= "")
    specify log levels for modules
--quiet  (= false)
    show no informational output
--show-log  (= false)
    if set, write the log file to stderr
--verbose  (= false)
    show more verbose output
Command Options:
--format  (= tabular)
    Specify output format (json|tabular|yaml)
-o, --output (= "")
    Specify an output file
Details:
Examples:
    juju regions aws
See also:
    add-cloud
    clouds
    show-cloud
    update-clouds
Aliases: list-regions
Thanks for the heads up @anastasia-macmood. But this is a direct import from the current documentation (https://docs.jujucharms.com/commands).
@anthonydillon,
This feels like a waste of your effort to import outdated information from jujucharms.com.
In addition that they are outdated, some commands and their help vary between Juju versions.
This effort needs to be better coordinated between our teams.
I am happy to go around and fix all these pages that you’ve imported but why cannot it be done up front?
I am also pondering the value of having CLI help on the webpage… outdated or not
