Usage:
juju get-constraints [options] <application>
Summary:
Displays machine constraints for an application.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
--format (= constraints)
Specify output format (constraints|json|yaml)
-m, --model (= "")
Model to operate in. Accepts [:]|
-o, --output (= "")
Specify an output file
Details:
Shows machine constraints that have been set for an application with juju set- constraints
By default, the model is the current model.
Application constraints are combined with model constraints, set with juju set-model-constraints
, for commands (such as ‘deploy’) that provision
machines for applications. Where model and application constraints overlap, the
application constraints take precedence.
Constraints for a specific model can be viewed with juju get-model- constraints
Examples:
juju get-constraints mysql
juju get-constraints -m mymodel apache2
See also:
set-constraints
get-model-constraints
