Usage:
juju enable-ha [options]
Summary:
Ensure that sufficient controllers exist to provide redundancy.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--constraints (= "")
Additional machine constraints
--format (= simple)
Specify output format (json|simple|yaml)
-n (= 0)
Number of controllers to make available
-o, --output (= "")
Specify an output file
--to (= "")
The machine(s) to become controllers, bypasses constraints
Details:
To ensure availability of deployed applications, the Juju infrastructure must itself be highly available. The enable-ha command will ensure that the specified number of controller machines are used to make up the controller.
An odd number of controllers is required.
Examples:
# Ensure that the controller is still in highly available mode. If
# there is only 1 controller running, this will ensure there
# are 3 running. If you have previously requested more than 3,
# then that number will be ensured.
juju enable-ha
# Ensure that 5 controllers are available.
juju enable-ha -n 5
# Ensure that 7 controllers are available, with newly created
# controller machines having at least 8GB RAM.
juju enable-ha -n 7 --constraints mem=8G
# Ensure that 7 controllers are available, with machines server1 and
# server2 used first, and if necessary, newly created controller
# machines having at least 8GB RAM.
juju enable-ha -n 7 --to server1,server2 --constraints mem=8G
