`juju disabled-commands`
Usage:
juju disabled-commands [options]
Summary:
List disabled commands.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--all  (= false)
Lists for all models (administrative users only)
--format  (= tabular)
Specify output format (json|tabular|yaml)
-m, --model (= "")
Model to operate in. Accepts `[:]|
-o, --output (= "")`
Specify an output file
Details:
List disabled commands for the model.
Commands that can be disabled are grouped based on logical operations as follows:
“destroy-model” prevents:
destroy-controller
destroy-model
“remove-object” prevents:
destroy-controller
destroy-model
detach-storage
remove-application
remove-machine
remove-relation
remove-saas
remove-storage
remove-unit
“all” prevents:
add-machine
add-relation
add-unit
add-ssh-key
add-user
attach-resource
attach-storage
change-user-password
config
consume
deploy
destroy-controller
destroy-model
disable-user
enable-ha
enable-user
expose
import-filesystem
import-ssh-key
model-defaults
model-config
reload-spaces
remove-application
remove-machine
remove-relation
remove-ssh-key
remove-unit
remove-user
resolved
retry-provisioning
run
scale-application
set-credential
set-constraints
set-series
sync-agents
unexpose
upgrade-charm
upgrade-model
See also:
disable-command
enable-command
Aliases:
list-disabled-commands
