Usage:
juju destroy-controller [options] <controller name>
Summary:
Destroys a controller.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
--destroy-all-models (= false)
Destroy all hosted models in the controller
--destroy-storage (= false)
Destroy all storage instances managed by the controller
--force (= false)
Force destroy hosted models ignoring any errors
--model-timeout (= 30m0s)
Timeout before each individual hosted model destruction is aborted
--no-wait (= false)
Rush through hosted model destruction without waiting for each individual step to complete
--release-storage (= false)
Release all storage instances from management of the controller, without destroying them
-y, --yes (= false)
Do not ask for confirmation
Details:
All models (initial model plus all workload/hosted) associated with the
controller will first need to be destroyed, either in advance, or by
specifying --destroy-all-models
If there is persistent storage in any of the models managed by the
controller, then you must choose to either destroy or release the
storage, using --destroy-storage
or --release-storage
respectively.
Sometimes, the destruction of a hosted model may fail as Juju encounters errors that need to be dealt with before that model can be destroyed. However, at times, there is a need to destroy a controller ignoring such model errors. In these rare cases, use --force option but note that --force will also remove all units of any hosted applications, their subordinates and, potentially, machines without given them the opportunity to shutdown cleanly.
Model destruction is a multi-step process. Under normal circumstances, Juju will not proceed to the next step until the current step has finished. However, when using --force, users can also specify --no-wait to progress through steps without delay waiting for each step to complete.
Examples:
# Destroy the controller and all hosted models. If there is
# persistent storage remaining in any of the models, then
# this will prompt you to choose to either destroy or release
# the storage.
juju destroy-controller --destroy-all-models mycontroller
# Destroy the controller and all hosted models, destroying
# any remaining persistent storage.
juju destroy-controller --destroy-all-models --destroy-storage
# Destroy the controller and all hosted models, releasing
# any remaining persistent storage from Juju's control.
juju destroy-controller --destroy-all-models --release-storage
# Destroy the controller and all hosted models, continuing
# even if there are operational errors.
juju destroy-controller --destroy-all-models --force
juju destroy-controller --destroy-all-models --force --no-wait
See also:
kill-controller
unregister
