`juju default-region`
Usage:
juju default-region [options] <cloud name> [<region>]
Summary:
Sets the default region for a cloud.
Global Options:
--debug  (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help  (= false)
--logging-config (= "")
specify log levels for modules
--quiet  (= false)
show no informational output
--show-log  (= false)
if set, write the log file to stderr
--verbose  (= false)
show more verbose output
Command Options:
--reset  (= false)
Reset default region for the cloud
Details:
The default region is specified directly as an argument.
To unset previously set default region for a cloud, use --reset option.
To confirm what region is currently set to be default for a cloud, use the command without region argument.
Examples:
juju default-region azure-china chinaeast
juju default-region azure-china --reset
See also:
add-credential
Aliases:
set-default-region
