Usage:
juju default-credential [options] <cloud name> [<credential name>]
Summary:
Sets local default credentials for a cloud on this client.
Global Options:
--debug (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help (= false)
--logging-config (= "")
specify log levels for modules
--quiet (= false)
show no informational output
--show-log (= false)
if set, write the log file to stderr
--verbose (= false)
show more verbose output
Command Options:
--reset (= false)
Reset default credential for the cloud
Details:
The default credentials are specified with a “credential name”.
A credential name is created during the process of adding credentials either
via juju add-credential
or juju autoload-credentials
Credential names can be listed with juju credentials
This command sets a locally stored credential to be used as a default. Default credentials avoid the need to specify a particular set of credentials when more than one are available for a given cloud.
To unset previously set default credential for a cloud, use --reset
option.
To view currently set default credential for a cloud, use the command without a credential name argument.
Examples:
juju default-credential google credential_name
juju default-credential google --reset
See also:
credentials
add-credential
remove-credential
Aliases:
set-default-credential
