`juju config`
Usage:
juju config [options] <application name> [--branch <branch-name>] [--reset <key[,key]>] [<attribute-key>][=<value>] ...]
Summary:
Gets, sets, or resets configuration for a deployed application.
Global Options:
--debug  (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help  (= false)
--logging-config (= "")
specify log levels for modules
--quiet  (= false)
show no informational output
--show-log  (= false)
if set, write the log file to stderr
--verbose  (= false)
show more verbose output
Command Options:
--file  (= )
path to yaml-formatted application config
--format  (= yaml)
Specify output format (json|yaml)
-m, --model (= "")
Model to operate in. Accepts [:]|
-o, --output (= "")
Specify an output file
--reset  (= )
Reset the provided comma delimited keys
Details:
If no config key is specified, all configuration items (keys, values, metadata) for the application will be printed out.
The entire set of available config settings and their current values can be listed by running "juju config ". For example, to obtain the config settings for apache2 you can run:
juju config apache2
When listing config settings, this command will, by default, format its output as a yaml document. To obtain the output formatted as json, the --format json flag can be specified. For example:
juju config apache2 --format json
The settings list output includes the name of the charm used to deploy the application and a listing of the application-specific configuration settings. See juju status for the set of deployed applications.
To obtain the configuration value for a specific setting, simply specify its name as an argument, e.g. juju config apache2 servername. In this case, the command will ignore any provided --format option and will instead output the value as plain text. This allows external scripts to use the output of a juju config <application name> <setting name> invocation as an input to an expression or a function.
To set the value of one or more settings, provide each one as a key/value pair argument to the command invocation. For instance:
juju config apache2 servername=example.com lb_balancer_timeout=60
A single setting value may be set via file. The following example uses a file “/tmp/servername” with contents “example.com”:
juju config apache2 servername=@/tmp/servername
By default, any configuration changes will be applied to the currently active branch. A specific branch can be targeted using the --branch option. Changes can be immediately be applied to the model by specifying --branch=master. For example:
juju config apache2 --branch=master servername=example.com
juju config apache2 --branch test-branch servername=staging.example.com
Rather than specifying each setting name/value inline, the --file flag option may be used to provide a list of settings to be updated as a yaml file. The yaml file contents must include a single top-level key with the application’s name followed by a dictionary of key/value pairs that correspond to the names and values of the settings to be set. For instance, to configure apache2, the following yaml file can be used:
apache2:
  servername: "example.com"
  lb_balancer_timeout: 60
If the above yaml document is stored in a file called config.yaml, the following command can be used to apply the config changes:
juju config --file config.yaml
Finally, the --reset flag can be used to revert one or more configuration settings back to their default value as defined in the charm metadata:
juju config apache2 --reset servername
juju config apache2 --reset servername,lb_balancer_timeout
See also:
deploy, status
