Usage:
juju clouds [options]
Summary:
Lists all clouds available to Juju.
Global Options:
--debug (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help (= false)
--logging-config (= "")
specify log levels for modules
--quiet (= false)
show no informational output
--show-log (= false)
if set, write the log file to stderr
--verbose (= false)
show more verbose output
Command Options:
--all (= false)
Show all available clouds
-c, --controller (= "")
Controller to operate in
--client (= false)
Client operation
--format (= tabular)
Specify output format (json|tabular|yaml)
--local (= false)
DEPRECATED (use --client): Local operation only; controller not affected
-o, --output (= "")
Specify an output file
Details:
Display the fundamental properties for each cloud known to Juju: name, number of regions, number of registered credentials, default region, type, etc…
Clouds known to this client are the clouds known to Juju out of the box
along with any which have been added with add-cloud --client
. These clouds can be
used to create a controller and can be displayed using --client option.
Clouds may be listed that are co-hosted with the Juju client. When the LXD hypervisor is detected, the ‘localhost’ cloud is made available. When a microk8s installation is detected, the ‘microk8s’ cloud is displayed.
Use --controller
option to list clouds from a controller.
Use --client
option to list clouds from this client.
This command’s default output format is ‘tabular’. Use ‘json’ and ‘yaml’ for machine-readable output.
Cloud metadata sometimes changes, e.g. providers add regions. Use the update-public-clouds
command to update public clouds or update-cloud
to update other clouds.
Use the regions
command to list a cloud’s regions.
Use the show-cloud
command to get more detail, such as regions and endpoints.
Further reading:
Documentation: https://juju.is/docs/olm/manage-clouds
microk8s: https://microk8s.io/
LXD hypervisor: https://linuxcontainers.org/lxd/
Examples:
juju clouds
juju clouds --format yaml
juju clouds --controller mycontroller
juju clouds --controller mycontroller --client
juju clouds --client
See also:
add-cloud
credentials
controllers
regions
default-credential
default-region
show-cloud
update-cloud
Aliases:
list-clouds
