Usage:
juju add-credential [options] <cloud name>
Summary:
Adds a credential for a cloud to a local client and uploads it to a controller.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client (= false)
Client operation
-f, --file (= "")
The YAML file containing credentials to add
--local (= false)
DEPRECATED (use --client
): Local operation only; controller not affected
--region (= "")
Cloud region that credential is valid for
--replace (= false)
DEPRECATED: Overwrite existing credential information
Details:
The juju add-credential
command operates in two modes.
When called with only the argument, juju add-credential
will
take you through an interactive prompt to add a credential specific to
the cloud provider.
Providing the -f <credentials.yaml>
option switches to the
non-interactive mode. <credentials.yaml> must be a path to a correctly
formatted YAML-formatted file.
Sample yaml file shows four credentials being stored against three clouds:
credentials:
aws:
<credential-name>:
auth-type: access-key
access-key: <key>
secret-key: <key>
azure:
<credential-name>:
auth-type: service-principal-secret
application-id: <uuid>
application-password: <password>
subscription-id: <uuid>
lxd:
<credential-name>:
auth-type: interactive
trust-password: <password>
<credential-name>:
The parameter of each credential is arbitrary, but must be unique within each . This allows each cloud to store multiple credentials.
The format for a credential is cloud-specific. Thus, it’s best to use
add-credential
command in an interactive mode. This will result in
adding this new credential locally and / or uploading it to a controller
in a correct format for the desired cloud.
The --replace
option is required if credential information
for the named cloud already exists locally. All such information will be
overwritten. This option is DEPRECATED, use juju update-credential
instead.
Examples:
juju add-credential google
juju add-credential google --client
juju add-credential google -c mycontroller
juju add-credential aws -f ~/credentials.yaml -c mycontroller
juju add-credential aws -f ~/credentials.yaml --client
Notes:
If you are setting up Juju for the first time, consider running
juju autoload-credentials
. This may allow you to skip adding
credentials manually.
This command does not set default regions nor default credentials for the
cloud. The commands juju default-region
and juju default-credential
provide that functionality.
Use --controller
option to upload a credential to a controller.
Use --client
option to add a credential to the current client.
See also:
