`juju add-cloud`
Related commands: clouds, update-cloud, remove-cloud, update-credential
See also: How to manage clouds
Usage:
juju add-cloud [options] <cloud name> [<cloud definition file>]
Summary:
Add a cloud definition to Juju.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--client  (= false)
Client operation
--credential (= "")
Credential to use for new cloud
-f, --file (= "")
The path to a cloud definition file
--force  (= false)
Force add cloud to the controller
--local  (= false)
DEPRECATED (use --client): Local operation only; controller not affected
--replace  (= false)
DEPRECATED: Overwrite any existing cloud information for
Details:
Juju needs to know how to connect to clouds. A cloud definition describes a cloud’s endpoints and authentication requirements. Each definition is stored and accessed later as .
If you are accessing a public cloud, running add-cloud is unlikely to be necessary. Juju already contains definitions for the public cloud providers it supports.
add-cloud operates in two modes:
juju add-cloud
juju add-cloud <cloud name> <cloud definition file>
When invoked without arguments, add-cloud begins an interactive session designed for working with private clouds. The session will enable you to instruct Juju how to connect to your private cloud.
A cloud definition can be provided in a file either as an option --f or as a positional argument:
juju add-cloud mycloud ~/mycloud.yaml
juju add-cloud mycloud -f ~/mycloud.yaml
When is provided with , Juju will validate the content of the file and add this cloud to this client as well as upload it to a controller.
Use --controller option to upload a cloud to a controller.
Use --client option to add cloud to the current client.
DEPRECATED (use update-credential instead): If already exists on this client, then the --replace option is required.
A cloud definition file has the following YAML format:
    clouds:                           # mandatory
      mycloud:                        # <cloud name> argument
        type: openstack               # <cloud type>, see below
            auth-types: [ userpass ]
                regions:
                  london:
                    endpoint: https://london.mycloud.com:35574/v3.0/
for private clouds:
 - lxd
 - maas
 - manual
 - openstack
 - vsphere
for public clouds:
 - azure
 - cloudsigma
 - ec2
 - gce
 - oci
When a running controller is updated, the credential for the cloud is also uploaded. As with the cloud, the credential needs to have been added to the current client, use add-credential to do that. If there’s only one credential for the cloud it will be uploaded to the controller automatically by add-cloud command. However, if the cloud has multiple credentials on this client you can specify which to upload with the --credential option.
When adding clouds to a controller, some clouds are whitelisted and can be easily added:
  • controller cloud type “kubernetes” supports [lxd maas openstack]
  • controller cloud type “lxd” supports [lxd maas openstack]
  • controller cloud type “maas” supports [maas openstack]
  • controller cloud type “openstack” supports [openstack]
Other cloud combinations can only be force added as the user must consider network routability, etc - concerns that are outside of scope of Juju. When forced addition is desired, use --force.
Examples:
juju add-cloud
juju add-cloud --force
juju add-cloud --controller mycontroller mycloud
juju add-cloud --controller mycontroller mycloud --credential mycred
juju add-cloud --client mycloud ~/mycloud.yaml
When using the add-cloud (and add-credential) command the user is questioned as to whether the operation should affect the client, the controller, or both. I don’t see any guidance in the documentation on what this is all about. On what understanding should a user base their decision upon?
BTW, on this page --local is deprecated and superseded by --client. However, in the text of the page the latter appears to be deprecated and superseded by update-credential. I’m guessing that this last part is a mistake.
p.s. The term “whitelisted” should be replaced by “allowlisted” or “are given preference” (other?).
