`juju actions`
Usage:
juju actions [options] <application>
Summary:
List actions defined for an application.
Global Options:
--debug  (= false)
equivalent to --show-log --logging-config==DEBUG
-h, --help  (= false)
--logging-config (= "")
specify log levels for modules
--quiet  (= false)
show no informational output
--show-log  (= false)
if set, write the log file to stderr
--verbose  (= false)
show more verbose output
Command Options:
--format  (= default)
Specify output format (default|json|tabular|yaml)
-m, --model (= "")
Model to operate in. Accepts [:]|
-o, --output (= "")
Specify an output file
--schema  (= false)
Display the full action schema
Details:
List the actions available to run on the target application, with a short description. To show the full schema for the actions, use --schema.
Examples:
juju list-actions postgresql
juju list-actions postgresql --format yaml
juju list-actions postgresql --schema
See also:
Aliases: list-actions
