Instructions on manila-ganesha specify to use juju deploy ./base.yaml --overlay ./manila-ganesha-overlay.yaml
. but is it possible to add manila-ganesha after deploying openstack bundle?
In principle, if you deployed with:
juju deploy ./bundle.yaml
you can deploy manila-ganesha with:
juju deploy ./bundle.yaml --overlay ./manila-ganesha-overlay.yaml
but you need to make sure the overlay doesn’t conflict. If it does, the output to the above command will let you know.
