Installing Charmed OSM with MicroK8s
This guide will walk you through installing Charmed OSM.
Current version: OSM v7.0.1
Upstream documentation
Requirements
We suggest the following minimum requirements:
  • Ubuntu Bionic
  • 4 CPU
  • 8 GB RAM
  • 50G free disk space
Getting Started
Install the basic prerequisites.
sudo snap install osmclient
Alias
The osm command will be available via osmclient.osm. You can create an alias to osm with the following command:
$ sudo snap alias osmclient.osm osm
Added:
  - osmclient.osm as osm
Connect Snap Interface
By default, snaps need to be given permissions to read hidden resources in your home directory. This will allow the osmclient snap to access your Juju configuration, your public SSH keys, and get some networking information.
sudo snap connect osmclient:juju-client-observe
sudo snap connect osmclient:ssh-public-keys
sudo snap connect osmclient:network-control
Bootstrap Juju on LXD
NOTE: It is not necessary to use sudo with any juju command. Doing so may lead to permission denied errors.
Bootstrap the Juju controller, on LXD, that OSM will use to deploy proxy charms.
Before that, make sure LXD is installed and configured correctly to work with Charmed OSM
juju bootstrap localhost osm-lxd
Install and configure MicroK8s
MicroK8s is a fast, lightweight, and certified distribution of Kubernetes that is made for developers. It’s a great choice if you want Kubernetes within minutes.
sudo snap install microk8s --classic
sudo usermod -a -G microk8s `whoami`
newgrp microk8s
microk8s.status --wait-ready
microk8s.enable storage dns
# For easier access, create an alias to microk8's kubectl command
sudo snap alias microk8s.kubectl kubectl
# Bootstrap the Kubernetes cloud
juju bootstrap microk8s osm-k8s
# Add a new model for OSM
juju add-model osm
Install OSM
Generate a bundle overlay containing the credentials of our OSM Juju controller and deploy
osmclient.overlay
NOTE: When executing this command, a vca-overlay.yaml file will be generated in your current directory, and also some commands will be printed out for you to execute. Those commands will enable full-charm support.
Deployment
Choose how you would like Charmed OSM to be deployed.
Standalone
The standalone version is perfect for evaluation and development purposes. Each component is installed with a single instance, ideal for running on a laptop or workstation, pairing well with microk8s.
juju deploy osm --overlay vca-overlay.yaml
High-Availability
For production use, we offer a high-availability version of Charmed OSM. Each component will be deployed in clusters of three units setup with failover, and requires significantly more resources to operate.
juju deploy osm-ha --overlay vca-overlay.yaml
Status
It can take several minutes or longer to install, depending on your machine and bandwidth. To monitor the progress of the installation, you can watch the output of juju status:
$ watch -c juju status --color
Every 2.0s: juju status --color        micro-osm: Fri Aug 23 17:03:25 2019
Model  Controller  Cloud/Region        Version  SLA          Timestamp
osm       osm-k8s  microk8s/localhost  2.6.6    unsupported  17:03:27Z
App             Version  Status  Scale  Charm           Store       Rev  OS          Address         Notes
grafana-k8s              active      1  grafana-k8s     jujucharms   15  kubernetes  10.152.183.122
kafka-k8s                active      1  kafka-k8s       jujucharms    1  kubernetes  10.152.183.90
lcm-k8s                  active      1  lcm-k8s         jujucharms   21  kubernetes  10.152.183.44
mariadb-k8s              active      1  mariadb-k8s     jujucharms   16  kubernetes  10.152.183.75
mon-k8s                  active      1  mon-k8s         jujucharms   14  kubernetes  10.152.183.231
mongodb-k8s              active      1  mongodb-k8s     jujucharms   15  kubernetes  10.152.183.15
nbi-k8s                  active      1  nbi-k8s         jujucharms   24  kubernetes  10.152.183.104
pol-k8s                  active      1  pol-k8s         jujucharms   14  kubernetes  10.152.183.230
prometheus-k8s           active      1  prometheus-k8s  jujucharms   14  kubernetes  10.152.183.13
ro-k8s                   active      1  ro-k8s          jujucharms   20  kubernetes  10.152.183.56
ui-k8s                   active      1  ui-k8s          jujucharms   28  kubernetes  10.152.183.7
zookeeper-k8s            active      1  zookeeper-k8s   jujucharms   16  kubernetes  10.152.183.140
Unit               Workload  Agent  Address    Ports                       Message
grafana-k8s/0*     active    idle   10.1.1.39  3000/TCP                    configured
kafka-k8s/0*       active    idle   10.1.1.32  9092/TCP                    configured
lcm-k8s/0*         active    idle   10.1.1.36  80/TCP                      configured
mariadb-k8s/0*     active    idle   10.1.1.24  3306/TCP                    ready
mon-k8s/0*         active    idle   10.1.1.33  8000/TCP                    configured
mongodb-k8s/0*     active    idle   10.1.1.26  27017/TCP                   configured
nbi-k8s/0*         active    idle   10.1.1.35  9999/TCP                    configured
pol-k8s/0*         active    idle   10.1.1.34  80/TCP                      configured
prometheus-k8s/0*  active    idle   10.1.1.38  9090/TCP                    configured
ro-k8s/0*          active    idle   10.1.1.30  9090/TCP                    configured
ui-k8s/0*          active    idle   10.1.1.37  80/TCP                      configured
zookeeper-k8s/0*   active    idle   10.1.1.31  2181/TCP,2888/TCP,3888/TCP  configured
When all Status and Workloads are shown in an active state, your installation of OSM is ready to use.
Post-deployment
Once Charmed OSM has been successfully installed, set the OSM_HOSTNAME.
First, get the IP address of the nbi-k8s application.
$ juju status nbi-k8s
osm    osm-on-k8s  microk8s/localhost  2.6.6    unsupported  17:15:10Z
Next, export the OSM_HOSTNAME variable and confirm that the platform is operational:
$ export OSM_HOSTNAME=10.152.183.104
You may now interact with Charmed OSM via the osm command. To make this persistent across sessions, it’s recommended to add this to your ~/.bashrc.
$ osm vim-list
| vim name | uuid |
$ osm user-list
| name  | id                                   |
| admin | 51b369ed-942e-4a61-a031-64eaa15e8cff |
Hi @aisrael how can I debug an app that keep “waiting” ?
ubuntu@osm-rel6-k8s:~$ juju status
osm    osm-on-k8s  microk8s/localhost  2.6.6    unsupported  18:46:58Z
grafana-k8s              active       1  grafana-k8s     jujucharms   15  kubernetes  10.152.183.192
kafka-k8s                active       1  kafka-k8s       jujucharms    1  kubernetes  10.152.183.135
lcm-k8s                  waiting      1  lcm-k8s         jujucharms   21  kubernetes  10.152.183.229
mariadb-k8s              waiting      1  mariadb-k8s     jujucharms   16  kubernetes  10.152.183.138
mon-k8s                  active       1  mon-k8s         jujucharms   14  kubernetes  10.152.183.7
mongodb-k8s              active       1  mongodb-k8s     jujucharms   15  kubernetes  10.152.183.65
nbi-k8s                  active       1  nbi-k8s         jujucharms   24  kubernetes  10.152.183.112
pol-k8s                  active       1  pol-k8s         jujucharms   14  kubernetes  10.152.183.81
prometheus-k8s           active       1  prometheus-k8s  jujucharms   14  kubernetes  10.152.183.9
ro-k8s                   active       1  ro-k8s          jujucharms   20  kubernetes  10.152.183.173
ui-k8s                   active       1  ui-k8s          jujucharms   28  kubernetes  10.152.183.45
zookeeper-k8s            active       1  zookeeper-k8s   jujucharms   16  kubernetes  10.152.183.2
grafana-k8s/0*     active    idle   10.1.1.12  3000/TCP                    configured
kafka-k8s/0*       active    idle   10.1.1.21  9092/TCP                    configured
lcm-k8s/0*         active    idle   10.1.1.14  80/TCP                      configured
mariadb-k8s/0*     active    idle   10.1.1.31  3306/TCP                    ready
mon-k8s/0*         active    idle   10.1.1.11  8000/TCP                    configured
mongodb-k8s/0*     active    idle   10.1.1.28  27017/TCP                   configured
nbi-k8s/0*         active    idle   10.1.1.33  9999/TCP                    configured
pol-k8s/0*         active    idle   10.1.1.24  80/TCP                      configured
prometheus-k8s/0*  active    idle   10.1.1.25  9090/TCP                    configured
ro-k8s/0*          active    idle   10.1.1.32  9090/TCP                    configured
ui-k8s/0*          active    idle   10.1.1.17  80/TCP                      configured
zookeeper-k8s/0*   active    idle   10.1.1.16  2181/TCP,2888/TCP,3888/TCP  configured
The waiting state means that Juju expects to be able to proceed, once something else is completed that it needs to install or configure. No action should be required from you.
It is possible though that lcm-k8s and mariadb-k8s are waiting for a relations to be established. Perhaps the overlay bundle step in the “Install OSM” section needs more explanation:
Hello @guilag,
First of all, thanks for installing Charmed OSM.
When an application is in waiting status, it’s generally because the workload kubernetes pod is in a CrashLoopBackOff state, or not ready. This problem usually has to do with mariadb-k8s application, that is not starting properly. Because of that, the ro-k8s is not properly initialized, and the lcm-k8s, which has a relation with the ro-k8s is failing too.
In order to debug, I would recommend you to execute the following commands:
kubectl -n osm get pods # list all the pods
kubectl -n osm logs mariadb-k8s-0 # show logs of the mariadb-k8s-0 pod
kubectl -n osm describe pods mariadb-k8s-0 # show pod details
kubectl -n osm get pods mariadb-k8s-0 -o yaml # show the deployment yaml
I would appreciate if you could open a bug here, and put there the logs of the previous commands. Also it would be nice if you could specify the OS version you’re using, whether you are installing it in a VM or not, memory, disk space, etc.
Thanks,
David García
Hi @davigar15,
thx, I will try your commands.
Here is my ubuntu version:
ubuntu@osm-rel6-k8s:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.2 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.2 LTS"
VERSION_ID="18.04"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
Here are my resources:
Running in a VM in OpenStack
RAM 12GB
VCPUs 20 VCPU
Disk 100GB
Hello @guilag,
Okay, it’s weirdbecause I just tried it in the same environment as you, and with fewer resources.
We’ll try to figure out why is this happening. In the meantime do the following:
juju destroy-model osm --destroy-storage -y
juju add-model osm
juju create-storage-pool osm-pv kubernetes storage-class=microk8s-hostpath
juju create-storage-pool packages-pv kubernetes storage-class=microk8s-hostpath
juju deploy osm --overlay vca-overlay.yaml --channel edge
Hi, same status so far after running your commands:
osm    osm-on-k8s  microk8s/localhost  2.6.6    unsupported  19:28:30Z
grafana-k8s              active       1  grafana-k8s     jujucharms   19  kubernetes  10.152.183.242
kafka-k8s                active       1  kafka-k8s       jujucharms    4  kubernetes  10.152.183.199
lcm-k8s                  active       1  lcm-k8s         jujucharms   24  kubernetes  10.152.183.128
mariadb-k8s              waiting      1  mariadb-k8s     jujucharms   19  kubernetes  10.152.183.180
mon-k8s                  active       1  mon-k8s         jujucharms   18  kubernetes  10.152.183.125
mongodb-k8s              active       1  mongodb-k8s     jujucharms   18  kubernetes  10.152.183.154
nbi-k8s                  active       1  nbi-k8s         jujucharms   27  kubernetes  10.152.183.152
pol-k8s                  active       1  pol-k8s         jujucharms   18  kubernetes  10.152.183.127
prometheus-k8s           active       1  prometheus-k8s  jujucharms   18  kubernetes  10.152.183.230
ro-k8s                   waiting      1  ro-k8s          jujucharms   24  kubernetes  10.152.183.109
ui-k8s                   waiting      1  ui-k8s          jujucharms   32  kubernetes  10.152.183.126
zookeeper-k8s            active       1  zookeeper-k8s   jujucharms   25  kubernetes  10.152.183.47
grafana-k8s/0*     active    idle   10.1.1.51  3000/TCP                    ready
kafka-k8s/0*       active    idle   10.1.1.50  9092/TCP                    ready
lcm-k8s/0*         active    idle   10.1.1.55  9999/TCP                    ready
mariadb-k8s/0*     active    idle   10.1.1.44  3306/TCP                    ready
mon-k8s/0*         active    idle   10.1.1.54  8000/TCP                    ready
mongodb-k8s/0*     active    idle   10.1.1.46  27017/TCP                   ready
nbi-k8s/0*         active    idle   10.1.1.53  9999/TCP                    ready
pol-k8s/0*         active    idle   10.1.1.52  80/TCP                      ready
prometheus-k8s/0*  active    idle   10.1.1.47  9090/TCP                    ready
ro-k8s/0*          active    idle   10.1.1.49  9090/TCP                    ready
ui-k8s/0*          active    idle   10.1.1.56  80/TCP                      ready
zookeeper-k8s/0*   active    idle   10.1.1.48  2181/TCP,2888/TCP,3888/TCP  ready
Hi @aisrael,
I followed your installation but the “juju add-model osm” returns a:
ERROR ownership of the file is not the same as the current user: open /home/admin/.local/share/juju/controllers.yaml: permission denied
Do you have any suggestions?
Thank you!
Luca
