Event 'install'
Event > List of events > Lifecycle events > install
Source: ops.InstallEvent
This document describes the install event.
Contents:
Emission sequence
The install event is emitted once per unit at the beginning of a charm’s lifecycle. Associated callbacks should be used to perform one-time initial setup operations and prepare the unit to execute the application. Depending on the charm, this may include installing packages, configuring the underlying machine or provisioning cloud-specific resources.
Therefore, ways to cause install to occur are:
Scenario Example Command Resulting Events
Create unit juju deploy foo
juju add-unit foo
install -> config-changed
Note:
  • Typically, operations performed on install should also be considered for upgrade-charm.
  • In some cases, config-changed can be used instead of install and upgrade-charm because it is guaranteed to fire after both.
Observing this event in Ops
In ops, you can observe this event like you would any other:
# in MyCharm.__init__
self.framework.observe(self.on.install, self._on_install)
The install event object does not expose any specific attributes.
