Metrics and Alert rules provided by Hardware Observer for HPE Smart Array
Metrics
The details of the metrics exposed by Hardware Observer for HPE Smart Array Controllers are as follows:
Metric Name Description Labels
ssacli_command_success Indicates if the command is successful or not
ssacli_controllers Total number of controllers
ssacli_controller_info Shows information about controller part slot, part, status
ssacli_logical_drives The number of logical drives in the slot slot
ssacli_logical_drive_info Shows information about logical drive slot, drive_id, status
ssacli_physical_drives The number of physical drives in the slot slot
ssacli_physical_drive_info Shows information about physical drive slot, drive_id, status
Alerts
The details of the alerts that are provided by Hardware Observer for HPE Smart Array Controllers are as follows:
Alert Rule Name Description Severity
SsaCLICommandFailed Failed to run ssacli. critical
SsaCLIControllerNotFound ssacli controller not found. warning
SsaCLIControllerNotOK ssacli controller status not Ok. critical
SsaCLILogicalDriveNotOK ssacli logical drive status not Ok. critical
SsaCLIPhysicalDriveNotOK ssacli physical drive status not Ok. critical
