Bundles support charm resources (see Using resources) through the use of the resources
key. Consider the following charm metadata.yaml
file that includes a resource called pictures
summary: "example charm."
description: This is an example charm.
resources:
pictures:
type: file
filename: pictures.zip
description: "This charm needs pictures.zip to operate"
It might be desirable to use a specific resource revision in a bundle:
applications:
example-charm:
charm: "cs:example-charm"
series: trusty
resources:
pictures: 1
So here we specify a revision of ‘1’ from the Charm Store.
The resources
key can also specify a local path to a resource instead:
applications:
example-charm:
series: trusty
resources:
pictures: "./pictures.zip"
Local resources can be useful in network restricted environments where the controller is unable to contact the Charm Store.
