Introduction
Duration: 0:20
Nextcloud provides file hosting and several collaboration tools, like contacts, calendars and task boards.
The Collabora Online plugin allows for online collaborative document editing within the Nextcloud.
They’re easy to deploy and manage with Juju. Juju makes it practical to host a personal cloud.
Requirements
To make your way through this tutorial, you will need:
- Juju installed (see Installing Juju)
- a domain name that you control
Testing install
Open up a terminal prompt and run the juju version
command. If it reports a version, carry on. If not, retry the install steps.
$ juju version
2.7.5
What to do if you get stuck:
The best place to ask for help is the Juju Discourse forum.
If you prefer chatting, visit us on IRC or Matrix.
Establishing a Juju controller
Duration: 5:00
We require a Juju controller. You have two options:
Use the hosted JAAS controller (recommended for using Amazon AWS, Microsoft Azure and Google Compute Platform)
Otherwise use the bootstrap process to create a controller yourself
What is a Juju controller?: Juju uses a software agent called “the controller” to apply changes that you make and to monitor the system’s health. Read more about Juju controllers.
Using the hosted JAAS controller
The Juju team provide a controller that can interact with Juju models hosted on public clouds.
$ juju login jaas
Using JAAS keeps costs down. You’re not responsible for hosting the controller as well as your application(s).
Bootstrap process
To bootstrap Juju onto your own hardware, we need to register your hardware first. We will collect each machine into a “cloud”.
Once the cloud is available, we’ll be able to create a controller into it.
Using your own computer hardware
(Skip this step if you are planning to deploy to public clouds)
If you have your own server hardware, you can make use of the manual cloud to register your computers with Juju.
The juju add-cloud
command allows you to complete the registration process. It takes you through an interactive prompt where you will be asked to give a name to your cloud and SSH login details (user@10.10.10.100
in this example)
$ juju add-cloud
Cloud Types
lxd
maas
manual
openstack
vsphere
Select cloud type: manual
Enter a name for your manual cloud: home
Enter the controller's hostname or IP address: user@10.10.10.100
Cloud "home" successfully added
You may bootstrap with 'juju bootstrap home'
Create a controller
Use the juju bootstrap
command to create the controller. Add the name of the cloud you wish to deploy to as an argument.
$ juju bootstrap home
The juju bootstrap
command takes many options. Follow Getting Started with Juju for detailed instructions.
Which clouds does Juju support?:
Use the juju clouds
command to list the clouds that Juju knows about.
Creating a model
Duration: 0:30
A model is a workspace for our applications. It houses machines, and applications.
Complex models also include other components like networking spaces and persistent storage volumes.
$ juju add-model privcloud
Added 'privcloud' model on aws/us-west-1 with credential '<credential>' for user `<user>`
Adding machines
Duration: 5:00
We now need to add machines to our model. How to do this is subtly different depending on which cloud
Need to add many machines?
Outside of the home or small office environment, your hardware will be more complex. Multi-server we recommend installing MAAS and then configuring a MAAS cloud.
We want to be conservative with our compute resources, so we’ll add a large machine manually, then deploy Nextcloud and the backing database to that single machine.
On a public cloud
Juju can provision machines on our behalf:
juju add-machine --constraints="mem=8G root-disk=200G"
created machine 0
On a manual cloud
We re-register the machine that’s hosting the controller as a machine that’s hosting the model.
$ juju add-machine sssh:user@10.10.10.100
created machine 0
We’ll also add a small xenial (14.04) instance to manage the ssl-termination-proxy
charm. This will live as a container within machine 0.
$ juju add-machine lxd:0 --constraints="mem=256M"
created container 0/lxd/0
Deploy Nextcloud and PostgreSQL
Duration: 2:30
If you would like a “1 click” install, you can use this command deploy everything together. By default, it will use several machines rather than making use of containers on the host:
juju deploy cs:~erik-lonroth/bundle/nextcloud-collabora-tls
$ juju deploy cs:~erik-lonroth/nextcloud --to 0
Located charm "cs:~erik-lonroth/nextcloud-3".
Deploying charm "cs:~erik-lonroth/nextcloud-3".
Nextcloud requires a database. We’ll install PostgreSQL. We allocate 120GB of storage space.
$ juju deploy postgresql --storage pgdata=120G --to 0
Located charm "cs:postgresql-203".
Deploying charm "cs:postgresql-203".
Multi-tenant applications:
PostgreSQL and Nextcloud co-located on the same machine. To change this, we can add another unit of Nextcloud, then remove the nextcloud/0
unit. Juju provides us with the ability to start small and scale up as needed.
If you consult the juju status
output, you’ll notice an angry red “blocked” message in two places:
$ juju status
privcloud jaas aws/us-west-1 2.6.10 unsupported 15:31:23+13:00
nextcloud blocked 1 nextcloud jujucharms 3 ubuntu
postgresql 10.10 active 1 postgresql jujucharms 199 ubuntu
nextcloud/0* blocked idle 0 52.53.172.164 80/tcp Need Mysql or Postgres relation to continue
postgresql/0* active executing 0 52.53.172.164 5432/tcp (start) Live master (10.10)
0 started 52.53.172.164 i-0d1e5b3a3de5eb4ca bionic us-west-1c running
Now, we need to get the two applications to talk together.
$ juju relate nextcloud postgresql:db
It my take a minute or two for the system to re-configure itself, but juju status
will soon update itself to look more like this:
$ juju status
privcloud jaas aws/us-west-1 2.6.10 unsupported 15:35:07+13:00
nextcloud active 1 nextcloud jujucharms 3 ubuntu
nextcloud/0* active idle 0 52.53.172.164 80/tcp Ready
postgresql/0* active idle 0 52.53.172.164 5432/tcp Live master (10.10)
Accessing the Nextcloud login page
Duration: 1:30
Nextcloud is now fully operational. But accessing machine 0’s public IP address (52.53.172.164) on port 80 won’t yet show you a web page. We need to inform Juju to open the firewall.
juju expose nextcloud
If we visit the IP address now, we’re presented with a login screen (and some security warnings).
What to use for the login details?
Accessing the intial log in details for Nextcloud
Juju has created an admin account on our behalf using configuration parameters available in the charm.
We can access them via the juju config
commands:
$ juju config nextcloud admin-username
admin
$ juju config nextcloud admin-password
mypassword
Entering these values into the form should present you with the Nextcloud application. Take the opportunity to change the admin account’s password and create a non-admin user account.
it is possible to set your own admin password at deployment time via the --config
option. It wasn’t done there to keep things simple.
Adding HTTPS
Duration: 5:00
You now need to add a DNS record to a domain for nextcloud. We’ll assume cloud.example.com
. The A record needs to point at the IP address of the machine hosting the ssl-termination-proxy/0
unit.
An easy way to fetch the relevant IP address is to use the filtering and formatting options of the juju status
command:
juju status ssl-termination-proxy/0 --format=line
Produces
- ssl-termination-proxy/0: 54.215.139.236 (agent:idle, workload:active) 80/tcp, 443/tcp
With that information available, add the equivalent DNS entry:
cloud A 54.215.139.236 3600
Now, we set the config options for the relevant applications, we need to open the proxy to the Internet and add a relation between the ssl-termination-proxy and nextcloud-fqdn.
juju config nextcloud fqdn=cloud.example.com
juju config nextcloud-fqdn fqdns=cloud.example.com
juju expose ssl-termination-proxy
juju relate ssl-termination-proxy nextcloud-fqdn:ssl-termination
After a minute or so, juju status
output will converge to something that looks like this:
$ juju status
privcloud jaas aws/us-west-1 2.6.8 unsupported 16:14:23+13:00
nextcloud 16.0.1.1 active 1 nextcloud jujucharms 3 ubuntu exposed
nextcloud-fqdn active 1 ssl-termination-fqdn jujucharms 5 ubuntu
ssl-termination-proxy active 1 ssl-termination-proxy jujucharms 15 ubuntu exposed
nextcloud/0* active idle 0 52.53.172.164 80/tcp Nextcloud is OK.
ssl-termination-proxy/0* active idle 1 54.215.139.236 80/tcp,443/tcp Ready (cloud.example.com)
nextcloud-fqdn/0* active idle 54.215.139.236 Ready
1 started 54.215.139.236 i-03d027ce3a8f9fc2e xenial us-west-1b running
If yo you now access the page, you might be surprised at what you encounter:
Okay. The security warnings from the browser have gone, but a new one from Nextcloud has popped up. But that’s okay. We can use juju ssh
to make the recommended setting change.
Alter Nextcloud trusted_domains setting
We now need to tweak some settings within our Nextcloud instance to allow it to understand HTTPS.
The nextcloud charm that we’ve deployed supports an action that does this, add-trusted-domain
. Include the domain
and index
parameters.
$ juju run-action nextcloud/0 add-trusted-domain --wait domain="localhost" index=1
Action queued with id: <id>
Alter Nextcloud trusted_domains setting manually
If you want to know what’s happening under the hood, you can also perform this step yourself:
Access remote shell securely
Juju provides a helper command that understands how to connect to units directly without needing to refer back to their IP addresses:
juju ssh nextcloud/0
Now, we need to find where the application is stored. We’ll use the find
command to look for the file that
sudo find / -name 'config.sample.php' 2>/dev/null
/var/www/nextcloud/config/config.sample.php
Let’s look inside that directory:
ls /var/www/nextcloud/config/
CAN_INSTALL config.php config.sample.php
Great. config.php
definitely looks like what we want. Let’s make a backup and edit that file.
cd /var/www/nextcloud/config/
sudo cp config.php config.backup.php
Use your favourite editor: to edit the
sudo nano config.php
Edit the ‘trusted_domains’ line so that it includes your domain name:
<?php
$CONFIG = array (
'trusted_domains' => array ('cloud.example.com'),
Save the file.
Access Nextcloud over HTTPS
Duration: 0:10
Visiting your domain name with your browser should present you with a login page with no security warnings:
Deploying Collabora
Duration: 5:00
This section will be faster, as it is mostly a duplication of the steps taken for Nextcloud.
juju deploy cs:~erik-lonroth/collabora --config nextcloud_domain=cloud.example.com
juju deploy cs:~tengu-team/ssl-termination-fqdn collabora-fqdn --config fqdns=docs.example.com
While that is deploying, add a DNS record for your Collabora. Here is an example:
docs A 54.215.139.236 3600
Now, add the relations. After they’re added, your applications will automatically configure themselves.
juju relate collabora:website collabora-fqdn:website
juju relate collabora-fqdn:ssl-termination ssl-termination-proxy:ssl-termination
Install the Collabora Online plugin for Nextcloud
Duration: 3:00
This step requires you to adjust a setting within Nextcloud’s Administration menu.
Appendix: All steps as a single script
Juju is asynchronous and declarative. The commands in this tutorial can be executed in any order and will be resolved by Juju. Here they are as a single script that you can customise (be sure to update the configuration values):
juju deploy postgresql --storage pgdata=100G
juju deploy cs:~tengu-team/ssl-termination-proxy
juju deploy cs:~tengu-team/ssl-termination-fqdn nextcloud-fqdn
# database configuration
juju relate postgresql:db nextcloud:postgres
# nextcloud configuration
juju relate nextcloud:website nextcloud-fqdn:website
juju relate nextcloud-fqdn:ssl-termination ssl-termination-proxy:ssl-termination
# collabora configuration
juju config collabora nextcloud_domain=cloud.example.com
juju config collabora-fqdn fqdns=docs.example.com
# networking
Acknowledgements
Juju community member @erik-lonroth built the nextcloud
and collabora
charms to enable this.
The Tengu team, led by @merlijn-sebrechts, provided the Let’s Encrypt support.
