How to remove a controller
See also: Controller, Removing things reference
There are multiple ways to remove a controller. This document demonstrates each, in order of severity.
Contents:
Unregister a controller
See also: juju unregister
A controller can be unregistered from a client with:
juju unregister <controller-name>
For example:
juju unregister aws-controller
This removes local connection information from the local client. This command does not affect the controller itself in any way.
Destroy a controller
See also: juju destroy-controller
A controllercan be destroyed with:
juju destroy-controller <controller-name>
You will always be prompted to confirm this action. Use the -y option to override this.
As a safety measure, if there are any models (besides the ‘controller’ model) associated with the controller you will need to pass the --destroy-all-models option.
Additionally, if there is persistent storage in any of the controller’s models you will be prompted to either destroy or release the storage, using the --destroy-storage or --release-storage options respectively.
For example:
juju destroy-controller -y --destroy-all-models --destroy-storage aws
Use the kill-controller command as a last resort if the controller is not accessible for some reason.
Kill a controller
See also: juju kill-controller
The kill-controller command deserves some attention as it is very destructive and also has exceptional behaviour modes. This command will first attempt to remove a controller and its models in an orderly fashion. That is, it will behave like destroy-controller. If this fails, usually due the controller itself being unreachable, then the controller machine and the workload machines will be destroyed by having the client contact the backing cloud’s API directly.
