See also: Bundle, Juju SDK | How to manage bundles
This document shows how to perform various tasks related to charm bundles.
Contents:
- Query Charmhub for a bundle
- Deploy a bundle
- Export a model as a bundle
- Compare a bundle with a model
To see the bundles available for a given keyword on Charmhub, run the find
command followed by the keyword, for example:
juju find kubeflow
This will output a tabulated summary which also includes a ‘Bundle’ column. A result that gets a ‘Y’ in this column is a bundle.
See more:
juju find
Deploy a bundle
The procedure for how to deploy a bundle depends on whether you’re deploying a bundle from Charmhub or rather from your own local filesystem:
- To deploy a bundle from Charmhub, run the
deploy
command followed by the name of the bundle:
juju deploy <bundle>
- To deploy a bundle from your local filesystem, use the
deploy
command followed by the path to the local YAML file of the charm bundle that delivers the application:
juju deploy </path/to/bundle.yaml>
See more:
juju deploy
To export the current model configuration as a reusable bundle, run the export-bundle
command:
juju export-bundle
The command also has flags that allow you to select a different model, specify a name for the exported bundle, include charm configuration default values in the exported bundle, etc.
See more:
juju export-bundle
To compare a bundle with the current model and report any differences, run the diff-bundle
command:
juju diff-bundle <bundle>
Expand to see an example
Consider, for example, a model for which the status
command yields the output below:
docs lxd localhost/localhost 2.5.0 unsupported 05:22:22Z
haproxy unknown 1 haproxy jujucharms 46 ubuntu
mariadb 10.1.37 active 1 mariadb jujucharms 7 ubuntu
mediawiki 1.19.14 active 1 mediawiki jujucharms 19 ubuntu
haproxy/0* unknown idle 2 10.86.33.28 80/tcp
mariadb/0* active idle 1 10.86.33.192 ready
mediawiki/0* active idle 0 10.86.33.19 80/tcp Ready
0 started 10.86.33.19 juju-dbf96b-0 trusty Running
1 started 10.86.33.192 juju-dbf96b-1 trusty Running
2 started 10.86.33.28 juju-dbf96b-2 bionic Running
haproxy:peer haproxy:peer haproxy-peer peer
mariadb:cluster mariadb:cluster mysql-ha peer
mariadb:db mediawiki:db mysql regular
mediawiki:website haproxy:reverseproxy http regular
Now say we have a bundle file bundle.yaml
with these contents:
applications:
mediawiki:
charm: "mediawiki"
num_units: 1
options:
mysql:
charm: "mysql"
num_units: 1
options:
"binlog-format": MIXED
"block-size": 5
"dataset-size": "512M"
flavor: distro
"ha-bindiface": eth0
"ha-mcastport": 5411
"max-connections": -1
"preferred-storage-engine": InnoDB
"query-cache-size": -1
"query-cache-type": "OFF"
"rbd-name": mysql1
"tuning-level": safest
vip_cidr: 24
vip_iface: eth0
relations:
- - "mediawiki:db"
- "mysql:db"
Comparison of the currently active model with the bundle can be achieved in this way:
juju diff-bundle bundle.yaml
This produces an output of:
applications:
haproxy:
missing: bundle
mariadb:
missing: bundle
mediawiki:
charm:
bundle: mediawiki-5
model: mediawiki-19
series:
bundle: ""
model: trusty
options:
name:
bundle: Central library
model: null
mysql:
missing: model
machines:
"0":
missing: bundle
"1":
missing: bundle
"2":
missing: bundle
relations:
bundle-additions:
- - mediawiki:db
- mysql:db
model-additions:
- - haproxy:reverseproxy
- mediawiki:website
- - mariadb:db
- mediawiki:db
This informs us of the differences in terms of applications, machines, and relations. For instance, compared to the model, the bundle is missing applications haproxy
and mariadb
, whereas the model is missing mysql
. Both model and bundle utilise the ‘mediawiki’ application but they differ in terms of configuration. There are also differences being reported in the machines
and relations
sections.
Let’s now focus on the machines
section and explore some other features of the diff-bundle
command.
We can extend the bundle by including a bundle overlay. Consider an overlay bundle file changes.yaml
with these machine related contents:
applications:
mediawiki:
to: 2
mysql:
to: 3
machines:
"2":
series: trusty
constraints: arch=amd64 cores=1
"3":
series: trusty
Here, by means of the --overlay
option, we can add this extra information to the comparison, effectively inflating the configuration of the bundle:
juju diff-bundle bundle.yaml --overlay changes.yaml
This changes the machines
section of the output to:
machines:
"0":
missing: bundle
"1":
missing: bundle
"2":
series:
bundle: trusty
model: bionic
"3":
missing: model
The initial comparison displayed a lack of all three machines in the bundle. By adding machines 2
and 3
in the overlay, the output now shows machines 0
and 1
as missing in the bundle, machine 2
differs in configuration, and machine 3
is missing in the model.
As with the deploy
command, there is the ability to map machines in the bundle to those in the model. Below, the addition of --map-machines=2=0,3=1
makes, for the sake of the comparison, bundle machines 2
and 3
become model machines 0
and 1
, respectively:
juju diff-bundle bundle.yaml --overlay changes.yaml --map-machines=2=0,3=1
The machines
section now becomes:
machines:
"2":
missing: bundle
The bundle shows as only missing machine 2
now, which makes sense.
The target bundle can also reside within the online Charm Store. In that case you would simply reference the bundle name, such as wiki-simple
juju diff-bundle wiki-simple
See more:
juju diff-bundle
