See also:
When a Juju user logs in to a controller there are two basic scenarios:
- Logging in during user initialisation
- Logging in with an existing user
Each of these are described in greater detail on this page.
Terminology: A known controller is one that the local Juju client is aware of. It shows up in the output for the controllers
command and has its metadata recorded in ~/.local/share/juju/controllers.yaml
This scenario covers the case where a Juju user has never logged in to a controller. Doing so for the first time initialises the user, which involves, in particular, the creation of a password on the part of the Juju administrator. There are two sub-cases:
- Using the initial user token
- Using a re-generated user token
Doing either results in the controller becoming known to the client.
This is the “normal” way for initialising a user.
When a Juju user is added to a controller with the add-user
command a token is printed. This is provided to the person who will interact with Juju as that user. This token is then supplied to the register
command to register, and log in to, the controller:
juju register MHMTBHdpbGwUNTQuMjI2LjI....MCoLdEXylP6MRWITCHNvbWUtYXdz
Sample output:
Enter a new password: *******
Confirm password: *******
Enter a name for this controller [some-aws]: that-aws
Initial password successfully set for will.
Welcome, will. You are now logged into "that-aws".
There are no models available. You can add models with
"juju add-model", or you can ask an administrator or owner
of a model to grant access to that model with "juju grant".
The end result is that the controller is now known to this client:
juju controllers
Output:
Controller Model User Access Cloud/Region Models Nodes HA Version
that-aws* - will login - - - 2.6-beta2
There are some valid situations where a registration token may need to be re-generated for a Juju user:
- A login is desired from multiple clients.
- The original token was simply misplaced.
The end result is the same as in the first scenario. A new user will be initialised.
This is done with the change-user-password
command:
juju change-user-password --reset fred
Sample output:
Password for "fred" has been reset.
Ask the user to run:
juju register MHMTBHdpbGwwPxMUNQuMjI2LjI....IuMTonqYile1dhwTCHNvbWUtYXdz
Any previously generated token for user ‘fred’ is automatically invalidated.
This scenario covers the case where a Juju user has already logged in to the controller at least once from any device. Here, Juju is expecting a specific password for authentication to succeed. There are two sub-cases:
- Referencing a known controller by name
- Referencing an unknown controller by API endpoint
The API method results in the controller becoming known to the client.
This is the “normal” way for logging in to a controller:
juju login -c this-aws
Output:
Enter username: mike
please enter password for mike on this-aws: *******
Welcome, mike. You are now logged into "this-aws".
The login
command also accepts a username with the -u
option.
Logging in to an unknown controller via an API endpoint
Beginning with v.2.6.0
, a controller can be accessed via its API endpoint.
A few use cases for this feature:
- A controller is migrated and Juju users need to reconnect
The controller’s CA certificate is used to identify the controller to the Juju administrator. A fingerprint of the certificate will be displayed and the administrator will need to confirm that fingerprint before connecting.
If the controller is already known to the client then the command will print output guiding the administrator to use the non-API method, and then exit.
Note:
The endpoint method of logging in will only work if the controller itself is running v.2.6.0
Example
The API endpoint can be obtained from the show-controller
command on a client currently connected to the controller:
juju show-controller | grep endpoints
Sample output:
api-endpoints: ['54.226.250.155:17070']
The fingerprint of the CA certificate can be found similarly:
juju show-controller | grep fingerprint
Sample output:
ca-fingerprint: FA:B6:E3:E5:86:61:2F:D0:C8:45:DF:62:49:57:4C:78:BC:FE:83:79:29:71:49:E2:9E:D2:E2:18:2E:37:E9:EF
And now from a separate device:
juju login 54.226.250.155:17070 -c some-aws
The controller name is arbitrary, but hopefully meaningful, just like it is during the standard registration process.
Sample output:
Controller "54.226.250.155:17070" presented a CA cert that could not be verified.
CA fingerprint: [FA:B6:E3:E5:86:61:2F:D0:C8:45:DF:62:49:57:4C:78:BC:FE:83:79:29:71:49:E2:9E:D2:E2:18:2E:37:E9:EF]
Trust remote controller? (y/N): y
Enter username: admin
Enter password: *******
Welcome, admin. You are now logged into "some-aws".
There are 2 models available. Use "juju switch" to select
one of them:
- juju switch controller
- juju switch default
juju controllers
Output:
some-aws* - admin superuser 2 1 none 2.6-beta2
