How to integrate a local charm into a bundle
To integrate a local charm into a bundle, you will need a local bundle file, say bundle.yaml, where the charm field points to the directory of the charm in question. Here is an example:
series: xenial
applications:
  mysql:
    charm: "/home/ubuntu/charms/mysql"
    num_units: 1
    constraints: mem=2G cores=4
The bundle can then be deployed by using the file as the argument instead of a bundle name:
juju deploy ./bundle.yaml
With juju-2.9.42 it’s necessary to add charm file path, e.g.
applications:
  mysql:
    charm: "/home/ubuntu/charms/mysql/mysql_ubuntu-22.04-amd64.charm"
    num_units: 1
Failing to do so, is resulting in error like:
ERROR cannot deploy bundle: invalid charm "mysql": has no hooks nor dispatch file
