Commands can be disabled on a per-model basis to defend against unintentional changes. This is accomplished through the use of the disable-command
command with one of three increasingly restrictive command groups as an argument:
destroy-model
This group disables the ability to destroy both the model and its controller. -
remove-object
This group includes the previous group’s restrictions and also disables the removal of machines, relations, applications, and units. -
all
This group includes the previous group’s restrictions and disables all commands that can change the configuration of a model.
For example:
juju disable-command destroy-model
The table below lists all affected commands per group.
Adding a message
To give users an idea as to why a command is disabled, a message can be passed.
For example:
juju disable-command destroy-model "Check with SA before destruction."
If a user now attempts to destroy a protected model, they’d encounter an error similar to the following:
Destroying model
ERROR cannot destroy model: Check with SA before destruction.
destroy-model operation has been disabled for the current model.
To enable the command run
juju enable-command destroy-model
Re-enabling a command group
To re-enable a command group the enable-command
is used.
For example:
Listing disabled command groups
To list which command groups are disabled, use disabled-commands
juju disabled-commands
Example output:
Disabled commands Message
all
Command groups
This is the list of commands for each of the three command groups.
The kill-controller
command cannot be blocked.
destroy-model | remove-object | all |
destroy-controller | destroy-controller | add-relation |
destroy-model | destroy-machine | add-ssh-key |
destroy-model | add-unit | |
detach-storage | add-user | |
remove-application | attach-storage | |
remove-machine | change-user-password | |
remove-relation | config | |
remove-saas | consume | |
remove-storage | deploy | |
remove-unit | destroy-controller | |
destroy-model | ||
disable-user | ||
enable-ha | ||
enable-user | ||
expose | ||
import-filesystem | ||
import-ssh-key | ||
model-config | ||
model-defaults | ||
remove-application | ||
remove-machine | ||
remove-relation | ||
remove-ssh-key | ||
remove-unit | ||
remove-user | ||
resolved | ||
retry-provisioning | ||
run | ||
set-constraints | ||
set-credential | ||
set-series | ||
sync-agent-binaries | ||
unexpose | ||
upgrade-charm | ||
upgrade-model |
The above list was updated for v.2.6.0
