A model’s configuration influences all the machines residing within it and, in turn, the applications that get deployed onto those machines. It is therefore a very powerful feature to be able to configure at the model level. Model configuration consists of a collection of keys and their respective values. An explanation of how to both view and set these key:value pairs is provided below. Notable examples are provided at the end.
Getting and setting values
You can display the current model settings by running the command:
juju model-config
This will include all the currently set key values - whether they were set by you, inherited as a default value or dynamically set by Juju.
A key’s value may be set for the current model using the same command:
juju model-config no-proxy=jujucharms.com
It is also possible to specify a list of key-value pairs:
juju model-config test-mode=true enable-os-upgrade=false
Juju does not currently check that the provided key is a valid setting, so make sure you spell it correctly.
To set a null value:
juju model-config apt-mirror=""
To return a value to the default setting the --reset
flag is used, along with the key name:
juju model-config --reset test-mode
After deployment, the model-defaults
command allows a user to display the configuration values for a model as well as set default values that all new models will use. These values can even be specified for each cloud region instead of just the controller.
To set a default value for ‘ftp-proxy’, for instance, you would enter the following:
juju model-defaults ftp-proxy=10.0.0.1:8000
To see both the default values and what they’ve been changed to, you would use:
juju model-defaults
To set default values for all new models in a specific controller region, state the region in the command, shown here using the same example settings as our previous model-config
key-value pairs example above:
juju model-defaults us-east-1 test-mode=true enable-os-upgrade=false
Model settings can also be made when creating a new controller via either the --config
or --model-default
options. The difference being that --config
affects just the ‘controller’ and ‘default’ models while --model-default
affects all models, including any future ones. Below we use the --config
option:
juju bootstrap --config image-stream=daily localhost lxd-daily
The --config
or --model-default
need to be repeated for every setting, for example:
juju bootstrap microk8s uk8s \
--model-default logging-config="<root>=WARNING; unit=DEBUG" \
--model-default update-status-hook-interval="60m"
See Creating a controller for in-depth coverage on how to create a controller.
Note that these defaults can be overridden, on a per-model basis, during the invocation of the add-model
command (option --config
) as well as by resetting specific options to their original defaults through the use of the model-config
command (option --reset
Both the model-config
and model-defaults
commands can read key value pairs from a YAML-formatted file. For example:
juju model-config no-proxy=jujucharms.com more-config-values.yaml
List of model keys
The table below lists all the model keys which may be assigned a value and are not specific to a single cloud, additional info below. Some of these keys deserve further explanation. These are explored in the sections below the table.
Key | Type | Default | Valid values | Purpose |
agent-metadata-url | string | The URL of the private stream. | ||
agent-stream | string | released | released/devel/proposed | The stream to use for deploy/upgrades of agents. See additional info below. |
agent-version | string | The patch number to use for agents. See additional info below. | ||
apt-ftp-proxy | string | The APT FTP proxy for the model. See Offline mode strategies. | ||
apt-http-proxy | string | The APT HTTP proxy for the model. See Offline mode strategies. | ||
apt-https-proxy | string | The APT HTTPS proxy for the model. See Offline mode strategies. | ||
apt-mirror | string | The APT mirror for the model. See additional info below. | ||
automatically-retry-hooks | bool | true | Set the policy on retying failed hooks. See additional info below. | |
container-image-metadata-url | string | url | Corresponds to 'image-metadata-url' (see below) for cloud-hosted KVM guests or LXD containers. Not needed for the localhost cloud. | |
container-image-stream | string | url | Corresponds to 'image-stream' (see below) for cloud-hosted KVM guests or LXD containers. Not needed for the localhost cloud. | |
container-inherit-properties | string | Set parameters to be inherited from a machine to its hosted containers (KVM or LXD). See additional info below. | ||
container-networking-method | string | local/provider/fan | The FAN networking mode to use. Default values can be provider-specific. | |
datastore | string | A vSphere datastore name. | ||
default-series | string | valid series name, e.g. 'bionic' | The default series of Ubuntu to use for deploying charms. | |
default-space | string | The space used as the default binding when deploying charms. Will be "alpha" by default. | ||
development | bool | false | Set whether the model is in development mode. | |
disable-network-management | bool | false | Set whether to give network control to the provider instead of Juju controlling configuration. See additional info below. | |
enable-os-refresh-update | bool | true | Set whether newly provisioned instances should run their respective OS's update capability. See additional info below. | |
enable-os-upgrade | bool | true | Set whether newly provisioned instances should run their respective OS's upgrade capability. See additional info below. | |
external-network | string | A vSphere external network name. | ||
extra-info | string | This is a string to store any user-desired additional metadata. | ||
fan-config | string | overlay_CIDR=underlay_CIDR | The FAN overlay and underlay networks in CIDR notation (space-separated). | |
firewall-mode | string | instance | instance/global/none | The mode to use for network firewalling. See additional info below. |
ftp-proxy | string | url | The FTP proxy value to configure on instances, in the FTP_PROXY environment variable. See Offline mode strategies. | |
http-proxy | string | url | The HTTP proxy value to configure on instances, in the HTTP_PROXY environment variable. See Offline mode strategies. | |
https-proxy | string | url | The HTTPS proxy value to configure on instances, in the HTTPS_PROXY environment variable. See Offline mode strategies. | |
juju-ftp-proxy | string | The charm-centric FTP proxy value. See Offline mode strategies. | ||
juju-http-proxy | string | The charm-centric HTTP proxy value. See Offline mode strategies. | ||
juju-https-proxy | string | The charm-centric HTTPS proxy value. See Offline mode strategies. | ||
juju-no-proxy | string | The charm-centric no-proxy value. CIDR notation supported. See Offline mode strategies. | ||
ignore-machine-addresses | bool | false | When true, the machine worker will not look up or discover any machine addresses. | |
image-metadata-url | string | url | The URL at which the metadata used to locate OS image ids is located. | |
image-stream | string | The simplestreams stream used to identify which image ids to search when starting an instance. See additional info below. | ||
logforward-enabled | bool | false | Set whether the log forward function is enabled. | |
logging-config | string | The configuration string to use when configuring Juju agent logging (see this link for details). | ||
max-status-history-age | string | 72h, etc. | The maximum age for status history entries before they are pruned, in a human-readable time format. | |
max-status-history-size | string | 400M, 5G, etc. | The maximum size for the status history collection, in human-readable memory format. | |
no-proxy | string | List of domain addresses not to be proxied (comma-separated). See Offline mode strategies. | ||
primary-network | string | A vSphere primary network name. | ||
provisioner-harvest-mode | string | destroyed | all/none/unknown/destroyed | Set what to do with unknown machines. See additional info below. |
proxy-ssh | bool | false | Set whether SSH commands should be proxied through the API server. | |
resource-tags | string | none | A space-separated list of key=value pairs used to apply as tags on supported cloud models. | |
snap-http-proxy | string | The snap-centric HTTP proxy value. See Offline mode strategies. | ||
snap-https-proxy | string | The snap-centric HTTPS proxy value. See Offline mode strategies. | ||
snap-store-assertions | string | The collection of snap store assertions. Each entry should contain the snap store ID. | ||
snap-store-proxy | string | The snap store ID. See Offline mode strategies. | ||
ssl-hostname-verification | bool | true | Set whether SSL hostname verification is enabled. | |
test-mode | bool | false | Set whether the model is intended for testing. If true, accessing the charm store does not affect statistical data of the store. | |
transmit-vendor-metrics | bool | true | Set whether the controller will send metrics collected from this model for use in anonymized aggregate analytics. | |
update-status-hook-interval | string | 5m | 30s, 6m, 1hr, etc. | The run frequency of the update-status hook. The value has a random +/- 20% offset applied to avoid hooks for all units firing at once. Value change only honoured during controller and model creation (bootstrap --config and add-model --config ). |
vpc-id | string | The virtual private cloud (VPC) ID for use when configuring a new model to be deployed to a specific VPC during add-model . |
APT mirror
The APT packaging system is used to install and upgrade software on machines provisioned in the model, and many charms also use APT to install software for the applications they deploy. It is possible to set a specific mirror for the APT packages to use, by setting ‘apt-mirror’:
juju model-config apt-mirror=http://archive.ubuntu.com/ubuntu/
To restore the default behaviour you would run:
juju model-config --reset apt-mirror
The apt-mirror
option is often used to point to a local mirror. The Working offline page covers mirrors, proxies, and other aspects related to network-restricted environments.
APT updates and upgrades with faster machine provisioning
When Juju provisions a machine, its default behaviour is to upgrade existing packages to their latest version. If your OS images are fresh and/or your deployed applications do not require the latest package versions, you can disable upgrades in order to provision machines faster.
Two Boolean configuration options are available to disable APT updates and upgrades: enable-os-refresh-update
(apt update) and enable-os-upgrade
(apt upgrade), respectively.
enable-os-refresh-update: false
enable-os-upgrade: false
You may also want to just update the package list to ensure a charm has the latest software available to it by disabling upgrades but enabling updates.
Disable network management
This can only be used with MAAS models and should otherwise be set to ‘false’ (default) unless you want to take over network control from Juju because you have unique and well-defined needs. Setting this to ‘true’ with MAAS gives you the same behaviour with containers as you already have with other providers: one machine-local address on a single network interface, bridged to the default bridge.
Firewall mode
Modes available include:
- instance: Requests the use of an individual firewall per instance.
- global: Uses a single firewall for all instances (access for a network port is enabled to one instance if any instance requires that port).
- none: Requests that no firewalling should be performed inside the model, which is useful for clouds without support for either global or per instance security groups.
Juju lifecycle and harvesting
Juju keeps state on the running model and it can harvest (remove) machines which it deems are no longer required. This can help reduce running costs and keep the model tidy. Harvesting is guided by what “harvesting mode” has been set.
A Juju machine can be in one of four states:
- Alive: The machine is running and being used.
- Dying: The machine is in the process of being terminated by Juju, but hasn’t yet finished.
- Dead: The machine has been successfully brought down by Juju, but is still being tracked for removal.
- Unknown: The machine exists, but Juju knows nothing about it.
Juju can be in one of several harvesting modes, in order of most conservative to most aggressive:
- none: Machines will never be harvested. This is a good choice if machines are managed via a process outside of Juju.
- destroyed: Machines will be harvested if i) Juju “knows” about them and
ii) they are ‘Dead’. - unknown: Machines will be harvested if Juju does not “know” about them (‘Unknown’ state). Use with caution in a mixed environment or one which may contain multiple instances of Juju. - all: Machines will be harvested if Juju considers them to be ‘destroyed’ or ‘unknown’.
The default mode is destroyed.
Below, the harvest mode key for the current model is set to ‘none’:
juju model-config provisioner-harvest-mode=none
Retrying failed hooks
Juju retries failed hooks automatically using an exponential backoff algorithm. They will be retried after 5, 10, 20, 40 seconds up to a period of 5 minutes, and then every 5 minutes. The logic behind this is that some hook errors are caused by timing issues or the temporary unavailability of other applications - automatic retry enables the Juju model to heal itself without troubling the user.
However, in some circumstances, such as debugging charms, this behaviour can be distracting and unwelcome. For this reason, it is possible to set the automatically-retry-hooks
option to ‘false’ to disable this behaviour. In this case, users will have to manually retry any hook which fails, using the command above, as with earlier versions of Juju.
Even with the automatic retry enabled, it is still possible to use the juju resolved unit-name/#
command to retry manually.
Image streams
Juju, by default, uses the slow-changing ‘released’ images when provisioning machines. However, the image-stream
option can be set to ‘daily’ to use more up-to-date images, thus shortening the time it takes to perform APT package upgrades.
Agent versions and streams
A full definition of an agent is provided on the Concepts and terms page.
The agent-stream
option specifies the “stream” to use when a Juju agent is to be installed or upgraded. This setting reflects the general stability of the software and defaults to ‘released’, indicating that only the latest stable version is to be used.
To run the upcoming stable release (before it has passed the normal QA process) you can set:
agent-stream: proposed
For testing purposes, you can use the latest unstable version by setting:
agent-stream: devel
The agent-version
option specifies a “patch version” for the agent that is to be installed on a new controller relative to the Juju client’s current major.minor version (Juju uses a major.minor.patch numbering scheme).
For example, Juju 2.3.2 means major version 2, minor version 3, and patch version 2. On a client system with this release of Juju installed, the machine agent’s version for a newly-created controller would be the same. To specify a patch version of 1 (instead of 2), the following would be run:
juju bootstrap aws --agent-version='2.3.1'
If a patch version is available that is greater than that of the client then it can be targeted in this way:
juju bootstrap aws --auto-upgrade
Container inheritance
The container-inherit-properties
key allows for a limited set of parameters
enabled on a Juju machine to be inherited by any hosted containers (KVM guests
or LXD containers). The machine and container must be running the same series.
This key is only supported by the MAAS provider.
The parameters are:
- apt-primary
- apt-security
- apt-sources
- ca-certs
For MAAS v.2.5
or greater the parameters are:
- apt-sources
- ca-certs
For example:
juju model-config container-inherit-properties="ca-certs, apt-sources"
Cloud specific model keys
Cloud specific config keys are defined for the following cloud types: ec2, google, oci, and openstack. These config keys can be found by with the show-cloud command using the defined cloud name.juju show-cloud --include-config aws
