See also:
You have published your charm. This document shows you how you can now associate a resource name to your charm.
By default, a charm has no attached resources. You can verify this by running charmcraft resources
jdoe@machine:~/blogsystem$ charmcraft resources my-super-charm
No resources associated to my-super-charm.
To attach a resource to a charm, open your charm’s metadata.yaml
file and edit the resources
block:
jdoe@machine:~/blogsystem$ cat metadata.yaml
summary: My super charm.
description: My super duper charm, used for testing.
series:
- bionic
resources:
someresource:
type: file
filename: superdb.bin
description: the DB with needed info
You may include as many resources as we want.
When you’re done, rebuild and reupload your charm to Charmhub with the new metadata:
jdoe@machine:~/blogsystem$ charmcraft build
Created 'my-super-charm.charm'.
jdoe@machine:~/blogsystem$ charmcraft upload my-super-charm.charm
Revision 13 of 'my-super-charm' created
Finally, inspect the results:
Name Type Revision Optional
someresource file 13 True
As you can see, the resource is associated to revision 13 of the charm. This association to a specific revision of a charm is important is important to keep in mind, as it will matter if you want to attach a resource to a charm at release time—the attachment will work only if the resource has been included in the chosen charm revision’s metadata.
